Old 06-27-2010, 08:31 PM   #1
c10seconds
c10seconds's Avatar
Wheel hop w/rear air ride strong arm kit... help
How can I get rid of the wheel hop? I just took it around the block for the first time since I installed the new detroit locker and now Im getting wheel hop. Im using the shocks that came with the kit. Would a shock upgrade fix this?
c10seconds is offline   Reply With Quote
Old 06-27-2010, 09:38 PM   #2
draggin86
draggin86's Avatar
Re: Wheel hop w/rear air ride strong arm kit... help
you can tri the upgraded QA1 shocks that are available for that kit
draggin86 is offline   Reply With Quote
Old 06-28-2010, 11:03 PM   #3
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
whats your pinion angle?
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 06-29-2010, 07:23 PM   #4
c10seconds
c10seconds's Avatar
Im not sure of the exact pinion angle. I havent changed it from its stock position. Could that be the issue?
Old 06-29-2010, 08:42 PM   #5
N2TRUX
Happy to be here
N2TRUX's Avatar
Please define "rear air ride strong arm kit". Do you mean Ride Tech's "Air Bar" kit or what? If so my guess is your shocks may be to soft. I haven't had any issues with that set up on mine, but then again I haven't hammered on it from a dead stop. From a rolling start mine will break loose and spin but no wheel hop.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 06-29-2010, 08:44 PM   #6
entourageguy
Yellow truck club
entourageguy's Avatar
I'd head over to the ride tech forum and ask them for suggestions ...
http://ridetech.com/forum/
Brian ......
My hub garage address
http://www.hubgarage.com/mygarage/59apache
I gue$$ everything has it'$ price
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
350 700r lokar shifter
power MII front end, shockwaves
tilt, 4 wheel discs
4-link and bags
10 bolt limited
entourageguy is offline   Reply With Quote
Old 06-29-2010, 10:59 PM   #7
c10seconds
c10seconds's Avatar
This is what I have and Im just using the standard shocks that come with the kit.
Old 06-30-2010, 11:30 AM   #8
N2TRUX
Happy to be here
N2TRUX's Avatar
Sorry bro, I didn't realize you were running their Trailing Arm system? How did the install go for you? You can post on their forum, or give them a call, but I'll but its shock related.
Articles-
"Refining Sierra"
Old 06-30-2010, 12:17 PM   #9
lolife99
67-72 parts collector,…
lolife99's Avatar
Just curious,... did it wheel hop any before?
Was it bagged before?
Do you think the locker has anything to do with it?
Keith
Convert to disc brakes.
Old 06-30-2010, 03:44 PM   #10
c10seconds
c10seconds's Avatar
No worries. The install was a breeze. The hardest part was removing all the rivets but even that with the right tools is pretty easy. Im guessing its shock related as well? I know you have one of their kits on your truck just not sure which one. Which shocks are you using?
Or maybe bag pressure has something to do with it?
lolife: It only started to hop after I installed the locker. Before the locker only one wheel was spinning and no hop
Old 06-30-2010, 04:58 PM   #11
SCOTI
SCOTI's Avatar
What air pressure are you running for the rears?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 07-03-2010, 04:03 PM   #12
c10seconds
c10seconds's Avatar
55 psi. Is the stock pinion angle supposed to be ok with this kit?
Old 07-07-2010, 11:51 AM   #13
65Gregg
65Gregg's Avatar
I may have missed this but when does it hop? When you hammer it, when you go around a corner or when?
65Gregg
Blue long bed
White TBSS
61 Impala
“The two most important days in your life are the day you are born and the day you find out why.” Mark Twain
65Gregg is offline   Reply With Quote
Old 07-07-2010, 12:09 PM   #14
c10seconds
c10seconds's Avatar
It does it when I hammer it from a dead stop
Old 07-07-2010, 12:23 PM   #15
SCOTI
SCOTI's Avatar
Sounds like the pinion angle does need to be adjusted for better results.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
