07-06-2010, 08:16 PM | #1 |
72 c-10 rear end breakdown
looking for a thread that someone has done on a rear end breakdown and rebuild. searched with no luck. any help would be great. thanks daniel.
07-07-2010, 01:48 PM | #2 |
Re: 72 c-10 rear end breakdown
maybe thats why i could not find one. haha.
07-07-2010, 02:00 PM | #3 |
I rebuilt my differential a few years ago and put a new posi unit in while I was doing it. Here are some links I used. If you have any specific questions as you are doing the rebuild just ask. Take your time with this job. It can be expensive if you make a mistake.
http://www.chevyhiperformance.com/te...all/index.html http://bertok.us/agreif/eaton/eatontech.htm http://www.precisiongear.com/tda.pdf http://67-72chevytrucks.com/vboard/s...0&postcount=10 http://www.hotrod.com/techarticles/d...ide/index.html |
07-07-2010, 02:04 PM | #4 |
the factory service manual has great instructions with pictures too
07-07-2010, 03:58 PM | #5 |
i just did a full 12 bolt rebuild this weekend, gears, locker, bearings, everything. just fire away with any questions, i'll do the best i can to answer. i would recommend buying a richmond gear set, with the master series install kit, and the carrier of your choice. you will need a few special tools. but nothing major. it just takes time to get everything set up perfect.
