Old 07-06-2010, 10:42 AM   #1
CentralCoaster
CentralCoaster's Avatar
Source for new steering gear box?
My steering box is trashed, no room left for adjustment, and has a blown seal.
I want to replace it with a variable ratio box. I know better than to buy some sh**** reman from Vatozone.
Who do you recommend? Also I read that some rebuilders don't replace the gears. I have a hard time seeing how the gears should be reused, as I bet the ones in my box are trash.
Thanks.
1969 C10 Stepside, 350ci, 700R4
CentralCoaster is offline   Reply With Quote
Old 07-06-2010, 10:47 AM   #2
Rack Man
Re: Source for new steering gear box?
Wes @ Classic Hearbeat sells an awesome unit....Its the Readhead brand...super high quality quick ratio units that are remanufactured (not rebuilt)....there's a huge difference!
http://www.classicheartbeat.com/67-72_chassis_2.htm
http://www.redheadsteeringgears.com/Index.html
RM
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=309288
Rack Man is offline   Reply With Quote
Old 07-06-2010, 11:53 AM   #3
CentralCoaster
What huge difference? IMO, reman is rebuilding, just on an assembly line, plus spray paint. Not that I care, either a proper rebuild or reman is fine.
Redhead says they put bearings in and custom fit the gears. I mean I assume they would put some "pretty good" gears in, but anyone out there that does new gears?
Also I don't see any variable ratio stuff on their site. I don't want a quick ratio in my truck.
"Machining out the housings and installing needle bearings
Flamespraying or replacing the shafts as needed
Installing new control valves on some applications
Custom fitting each worm & piston assembly with special ordered, precise oversized ball bearings
Old 07-06-2010, 12:00 PM   #4
c10seconds
c10seconds's Avatar
Here's a source.....http://www.agrperformance.com/catalo...ts.php?cat=101
c10seconds is offline   Reply With Quote
Old 07-06-2010, 12:26 PM   #5
CentralCoaster
Looks good. Where did my post go?
These guys have a new GM variable box for $295.
http://www.corvettesteering.com/truck_gears.htm
Found them on ebay also, but they say the 67-79 trucks have SAE fittings and the newer box is metric, requiring adapters. Grrr. Who knows, maybe I have metric lines, I doubt this truck came with power steering.
Seems like there's gotta be a reman cheaper than that with more new stuff.
Old 07-06-2010, 12:31 PM   #6
CentralCoaster
What were variable boxes used on new? Sounds strange that the "NEW GM" box would be different inside than what I already have.
Old 07-06-2010, 01:12 PM   #7
bglad420
bglad420's Avatar
I second the Redhead. Amazing steering boxes, and a lifetime warranty.
RedHead
70 GMC LWB Fleetside, 402BB, TH400 90K original only cost $50.
bglad420 is offline   Reply With Quote
Old 07-06-2010, 01:26 PM   #8
CentralCoaster
Old 07-06-2010, 01:39 PM   #9
CentralCoaster
Ok, my bad, I guess the Redhead site is a little lacking. I see they have variable boxes at classicheartbeat.
$300 plus $75 core. http://www.classicheartbeat.com/cata...ing%20Gear.htm
"***Note*** A core charge is added to all sales of Remanufactured Steering Gears. The core charge will be refunded if a rebuildable core is provided to us within 30 days of the purchase date. A rebuildable core will have no excessive ware, nor be disassembled. No worn, broken, scored, damaged, cracked, frozen or rusted housings. Also No broken or damaged mounting points."
Hmm, yeah I'm thinking my steering gear has excessive wear, which is why I'm replacing it. With my luck I'll pay $30 to ship it to them before finding that out I'm not getting $75 back.
Also on Redhead's variable ratio box, it says quicker ratio gears were installed... I also read on chevelles.net that there are 3 different fixed ratios and 3 different variable ratios from GM and Jeep on these. What ratio box are you guys using and would you do it differently the 2nd time around?
I'll pull my original gear and see if it has metric or SAE fittings, nothing on this thing is original. That new GM variable box at $295 is looking pretty good right now.
Old 07-06-2010, 01:53 PM   #10
CentralCoaster
Boo AGR. http://67-72chevytrucks.com/vboard/s...43&postcount=1
Old 07-06-2010, 02:55 PM   #11
CentralCoaster
Tried calling Wes to help decide on this box vs. new but I guess he's out of town until Thursdayish. Damn.
Old 07-06-2010, 03:08 PM   #12
CentralCoaster
Called the guy with the NOS GM variable boxes.... 12-16 ratio.
These are 79-up boxes with metric ports, and also he says GM reduced the input shaft from 13/16" to 3/4".
So if I have the 13/16 shaft I'd have to get a new rag joint section for $50 or from a junkyard to use with his box, plus adapters for the metric for another $10. Feck.
I'll have to take a look at my setup before I do anything and see what the previous owner put on there, if it's metric oring vs standard flare, and what steering shaft size.
Should have known this wouldn't be easy!
Old 07-06-2010, 03:27 PM   #13
bglad420
bglad420's Avatar
Red Head can custom built you a box too.
Old 07-07-2010, 01:30 PM   #14
CentralCoaster
I guess I'll go with the Redhead variable ratio. Less dicking around making the newer box fit, and all the feedback has been good. I just hate to think my core might not get refunded.
Old 07-07-2010, 01:59 PM   #15
basemodel67
Factory Strippers Rule!
basemodel67's Avatar
I wonder if I could get my manual steering box rebuilt with a quicker ratio?
"Feast your eyes on a feast of smoke."
67 Chevy Short Fleet
PLAN: LQ9, 4L60, D60
Looking for School Bus Gauges - Help me out!
basemodel67 is offline   Reply With Quote
Old 07-07-2010, 05:19 PM   #16
DustyC10
Whats the difference in the 69-72 Power Steering boxes as apposed to a 67-68 steering box? (Wondering about putting power steering on my 67)
DustyC10 is offline   Reply With Quote
Old 07-07-2010, 05:38 PM   #17
Thealien
Thealien's Avatar
Been running a redhead for about 3 years. I would highly recomend them!
Old 07-07-2010, 06:25 PM   #18
70cst
70cst's Avatar
RedHead
I third it. I bought mine from WES...
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 07-08-2010, 12:41 AM   #19
Indyuke
OR... you could get steering box out of a 77 c10. They are not too pricey, they bolt right in, and they're a variable ratio box.
Indyuke is offline   Reply With Quote
Old 07-08-2010, 07:10 PM   #20
CentralCoaster
Yeah, but then I'm back to gambling on used parts. It's almost impossible to find those pickups in the parts yards down here, most of the cars are 90+.
So I just forked out $340 for the Redhead with shipping.
Old 07-08-2010, 07:53 PM   #21
Hutch
Hutch's Avatar
I met these guy's at a swap meet.
They seem to know these units well
http://www.powersteering.com/
John Hutchison
Grapevine,Texas
68 1/2 t swb
68 Mustang
69 Jaguar
71 1/2 t swb
88 Supra CompTs6m
93 Escort GT
2005 Corolla XRS
Hutch is offline   Reply With Quote
Old 07-09-2010, 03:43 PM   #22
Indyuke
Well... I was talking about a new '77 unit from the auto parts store. I think they're about $80-$90.
Old 07-09-2010, 04:34 PM   #23
drunkbus
New Member
drunkbus's Avatar
I also went with Redhead and am happy with the product and service.
drunkbus is offline   Reply With Quote
Old 07-09-2010, 10:39 PM   #24
rich67
rich67's Avatar
seems like ratio in my 67 is alot slower than in my 70. noticable.
rich67 is offline   Reply With Quote
Old 07-10-2010, 12:31 AM   #25
CG
BlahBlahBlah
That would be a bummer, at least it wouldn't be as bad as what I did. I had a steering box sent in to redhead by a friend of mine for a rebuild. I'm sure its a great steering box (cost plenty to rebuild), unfortunately my buddy grabbed the wrong box, a manual steering box ... I wanted my power steering box rebuilt.
Now I have an expensive door stopper. No one wants to pay over 200 bucks for a manual steering box lol.
Like others have said though, Ive heard nothing but good stuff bout Redhead.
