#26 | |
Re: What is wrong here?!?!
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
#27 | |
Chevy Lover Till The End.
1969 Chevy SWB Big Block - Under the knife as of 12/26/2011 1989 Chevy Silverado, 4X4 - Daily Driver 1996 Chevy Suburban K1500 - 4-Wheeler, Campin Truck 1968 Chevrolet Impala Sport Coupe - 327/350hp, TH400, all original. Members I've met: BamaBaxter, My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=500359 |
#28 |
Hand Crafted C-10
![]() Join Date: Aug 2006
#29 | |
Your UncleBen
![]() Join Date: Dec 2002
![]() lata CHRIS
68 C10 shortbed -- Street/Strip ![]() |
#30 | |
Your UncleBen
lata CHRIS ![]() ![]()
68 C10 shortbed -- Street/Strip ![]() Last edited by SweetandLong68; 07-04-2010 at 02:31 PM. |
#31 | |
#32 | |
Your UncleBen
lata CHRIS
#33 |
Your UncleBen
I know we getting off topic here... But anyways! heheh This was the last time I took her to the track. The small block still has alot left but I aint worried with it too much. Just a fun street/strip car. Ran 7.50s though!
#34 |
Still plays with trucks
You could get a shorter belt and rotate the alternator closer to the engine and trim off the extra length on the adjuster arm. Weld just the closed end of the piece you cut off back onto the shortened adjuster to keep it strong. You only need to lose about an inch to clear that hose.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
#35 | |
Your UncleBen
thanks CHRIS
#36 |
#37 |
Hand Crafted C-10
SweetandLong68, here’s what I’ve got going.
1968 short water pump SBC, non-ac, 2wd. First pics are on my truck, clears the alternator adequately. Bought from parts store, per application. ![]() ![]() The 3rd picture is from my un-molested (doesn’t mean the PO bought the right hose but it does look like it would clear the alternator very well) parts truck. The next picture confirms that that radical S-curve was used. ![]() This picture is a radiator from a post-68 truck. ![]() I think both configurations would give you the room you need for your alternator. RockAuto says: Gates #20617 Goodyear #20715 AC Delco #20608x The above numbers would be for a hose like the one on my truck. IMHO-you would be better to get the right hose than mess with cobbling it together/shielding the wrong hose from harm or, gods-forbid, using a flex hose. Good Luck..E |
#38 | |
Your UncleBen
Also I hear where you are coming from about using a correct fitting hose. I stated this exact thing in a previous post! I did what I had to do by protecting the hose I have now until I can get the 'mo better fitting hose. THANKS! CHRIS BTW... Got any numbers on your altenator belt? lata CHRIS
#39 | |
Hand Crafted C-10
However, realize this pulley system was built on a wing and a prayer... nothing lined up but finally, I found I could use the pulley off my parts truck BUT that one has an old style alternator (don't know if it's the same diameter as mine) and no PS. The belt I had when it didn't line-up luckily fit but I had fitted for what I had before. Sorry, don't know how to word it better. Anyhow, because of this, I don't know whether it's a stock configuration or not. BTW-the Gatorback seems to have held up great for several years without any noise or other problems. If you go to Goodyear's site, you should be able to research the belts length and decide from there. Back in the day, we used to race and still had a bazillion belts laying around so I finally found one that would work and bought by length. Maybe short circuit the parts store and go talk to your local stock car racers and see if they also have oodles of old belts you can test-fit. If this has begun to be a fixation, you can go further, when you find that RIGHT belt. The local parts guy will stretch it out and usually get it wrong. Find that old guy still running his service station and ask if he has a belt measuring tool. And, no, it's not for sale. ![]() Good Luck!...this truly can be a PITA. Been there. . |
#40 |
Your UncleBen
Thanks for the info! Will check it out!
