Finally Completed 1-ton Conversion
Well, I swapped in a 14 Bolt full-floater and 8-lug Dana 44 some years ago with the intention of completing the 1-ton swap, but never got around to it until now. I located a Dana 60 with the right gears (4.10) recently at a good price so I pulled the trigger. The Dana 44 had served me well over the years, but I got tired of replacing the steering knuckle ball joints every couple years (oversized tires are hard on them), and the wheel bearings were also taking a beating. The Dana 60 was out of a Dodge, so the spring perches were about an inch wider apart than a GM unit, and the overall width of the axle is about 2 inches narrower than a GM unit. This makes the axle the same width as my rear 14 bolt, and it looks good (not the typical wider front track width that GM axles have). I got around the spring perch width issue by doing some creative trimming and stacking of the spring eye bushings to move each spring outboard by half an inch. Another benefit of the 60 is that I now get the 1-ton brake calipers and rotors up front to work with my disk brake conversion in the rear for some truly awesome braking. Here are some pics:
SKINNY TIRES RULE!
Re: Finally Completed 1-ton Conversion
Sounds like it was a successful project.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
I'm a poor spectator
Nice! But now I want to see more pics of that Bronco!
2006 Jeep Unlimited IMPACT ORANGE 1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig ![]() 1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!! ![]() 1979 Ford F150 4x4 SWB Built Ford Tough!!! ![]() 1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!! |
