Old 07-08-2010, 12:44 AM   #1
Jbesotes
Jbesotes's Avatar
Inline six shroud?
I am trying to find s shroud for my truck I have an inline six in my 70 chevy short bed c-10 anyone know where I can find one??
'70 Chevy Shorty
I support our troops!! Thank You to all that have served!!
Jbesotes is offline   Reply With Quote
Old 07-08-2010, 08:52 AM   #2
Shyguy
Junior Member
Shyguy's Avatar
Re: Inline six shroud?
I have never seen a shroud on a stock inline 6 setup. There is just a protective plate above the fan for safety.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 07-08-2010, 08:53 AM   #3
rusty baker
'70 C-10 Primer
rusty baker's Avatar
My 70, didn't have a shroud. I bought a chrome universal one several years ago, but can't remember where.
"The difference between stupidity and genius
is that genius has its limits." Albert Einstein
rusty baker is offline   Reply With Quote
Old 07-08-2010, 12:45 PM   #4
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
X2, no shroud just a plate.
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 07-08-2010, 12:47 PM   #5
Mt Man Chad
Mt Man Chad's Avatar
All I have ever seen is just a metal plate on top of the radiator.
I have one for sale if interested.
68 CST SWB - Gold/White 50th anniversary /TH350/Buddy Buckets/3.73 Posi/dogdish caps.
68 K10 Burb - Gold/White 327/SM465/NP205/3.73 "Daa Burb" build thread
Mt Man Chad is offline   Reply With Quote
Old 07-08-2010, 09:26 PM   #6
Jbesotes
Jbesotes's Avatar
I have a nice stainless steel plate on top right now I am just trying to find something that will help cool my motor better.
'70 Chevy Shorty
Old 07-08-2010, 10:06 PM   #7
Shyguy
Junior Member
Shyguy's Avatar
What temperature is your engine running? What fan does your engine have?
The 250 inline 6 in my '67 will set and idle and never get over 190, it has an after market temperature gage. The fan on my engine is a 4 blade fixed, no clutch.
Old 07-08-2010, 11:13 PM   #8
Jbesotes
Jbesotes's Avatar
I have a stock guage in my truck and and it is in the Hot!! after the truck werms up.
I also have a new cam and headers and an intake allong with a holley 2brl carb on it so it is going to run a littla hotter, I did put a clutch fan on it that is 18inches in diameter.
'70 Chevy Shorty
Old 07-09-2010, 07:08 AM   #9
ls1nova71
ls1nova71's Avatar
Some six cylinders did have a fan shroud, but I think it's only if the truck came originally with an automatic transmission. Mine had one, it was a 250 six with a 350 turbo trans, it looked just like one found on a small block truck, but the opening was off set to one side.
ls1nova71 is offline   Reply With Quote
Old 07-09-2010, 09:59 AM   #10
Mt Man Chad
Humm...
Very interesting!
Old 07-09-2010, 10:25 AM   #11
dnorris009
dnorris009's Avatar
Do you have the 3 row radiator?
Try changing thermostats?
I'm not sure how much cooler it'd run with a shroud.
Might have to go with a better radiator (V-8 4 row)
http://www.lmctruck.com/icatalog/cb/full.aspx?Page=125
or maybe even electric fans.
dnorris009 is offline   Reply With Quote
Old 07-09-2010, 12:17 PM   #12
Shyguy
Junior Member
Shyguy's Avatar
It is good to learn something new every day, thank you for sharing the photos.
Old 07-09-2010, 11:13 PM   #13
72BlckButy
Tot Roddin'
72BlckButy's Avatar
My '69 also had a shroud on it (all original) as it ran a 250 backed by a 2spd powerglide.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 07-09-2010, 11:46 PM   #14
Dark Knight
Dark Knight's Avatar
My truck used to run hot as well. I have the same engine. My problem turned out to be that the cylinder head had been over machined. New head and problem solved. You might try changing head gaskets and having the head checked by your local machine shop if you can. Or try changing to a lower temperature thermostat. Or easier yet, you can buy some Water Wetter or Purple Ice from Summit Racing or your local parts store. I would only use this option as a last resort. It should stay cool with no additives. Maybe check your water pump too. To do this, crank up your truck with the radiator cap off and wait until it warms up. You should see water circulating. Hope one of these things solves your problem.
-1967 Chevrolet Fleetside LWB- 350 V8 w/thumpr cam, NV3500, 3.08 gears, A/C, PS
-1983 Chevy Silverado C1500- 383 stroker, TH400
-1989 Chevy Silverado K1500 SWB- 5.3L swap, 700R4, 3.42 gears
-And a '66 Ford Mustang- 200 I6, C4 trans, rust bucket
"The only thing we have to fear is fear itself." -FDR (and maybe rust too)
You've gotta be able to stop and steer before you can go fast!
Dark Knight is offline   Reply With Quote
Old 07-10-2010, 12:34 AM   #15
Jbesotes
Jbesotes's Avatar
It only has a dual core radiator not a four, but I moved the clutch fan closer to the radiator hoping that it might pick up the heat faster, so I will know soon after I finish butting my new throtle pedal on it.
Thank You everyone for your advice.
'70 Chevy Shorty
