07-08-2010, 05:04 PM | #1 |
Re: Project: Recycle
I taped up the lense & played around w/the possible placement of 2x 3 3/8" & 4x 2 1/16" gauges. Not much room so you're kind of limited when trying to make things 'look' right vs. an eye-sore....
07-08-2010, 05:15 PM | #2 | |
Rollin' Old Skool
yeah, of all the styles i've seen using aftermarket gauges, that layout really looks best to me |
07-08-2010, 05:18 PM | #3 |
My plan was to re-use as much as possible from the original housing. I gutted what would no longer be needed & started tweaking from there . . ....
07-08-2010, 05:23 PM | #4 |
Once everything was trial fit, it came back apart for changing the lense's appearance & more aggressive clearancing of the OE housing for the deeper speedo/tach. This is what was trimmed off of the OE cluster housing (tin) & all the discarded internals....
07-08-2010, 05:31 PM | #5 |
I kept the original turn signal tubes & made another to match for the high beam indicator. The turn signal indicators are in the stock location & the high beam indicator was moved between the large gauges (not drilled yet).
I did .250" holes for the indicator lights after measuring the dimensions of the OE turn signal indicator 'arrows'....
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 07-08-2010 at 05:32 PM. |
07-08-2010, 05:44 PM | #6 |
I sanded/DA'd the lense w/some 80 grit & wiped it down w/degreaser. I used some Rustoleum 'Stone Creations' rattle-can texture finish that I picked up @ my local Home Depot. It gives a nice texture (like trunk spray/zolatone); but the texture is a little more aggressive.
I tried the standard 'wrinkle finish' rattle-can stuff but it requires everything to be just right when applying to get the 'best' finish. With this stuff, it's spray & go. I then used VHT's rattle-can epoxy 'satin black' as the top coat (I also sprayed a couple of coats on the back side of the lense). Overall, I was able to use the original housing parts & saved myself some cash. I can always go w/an aftermarket set-up if desired since this was just some time/effort. I included a close-up shot of the texture & one of the turn indicators. Next will be sandblasting the outer bezel & a fresh coat of VHT epoxy....
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 07-08-2010 at 06:46 PM. |
