Help with P2563 and P003a Code
something like this always happens when you are out of town
06 chevy 2500 duramax got the code P2563, and when i tried to clear it, at showed an error reading, so i unplugged the device (auto zone accutron reader??) and re-scanned, then the P003A code came up as pending, but it would not let me clear them. What does this mean??? i did a little research and found out it has something to do with the turbo?? Will it damage anything else to continue to drive it like it is--it seems to be working fine to me; however, i am not towing anything on this trip. have about a 4-5 hr drive back home.
My Build thread http://www.67-72chevytrucks.com/vboa...d.php?t=408574 |
Re: Help with P2563 and P003a Code
now the CEL is off, it still seems to be runnin fine
![]() Join Date: Jan 2003
I can't help much with the issue, but here is what I found for the codes:
2006 Chevy 2500 w/ 6.6L P2563-Turbocharger Boost Control Position Sensor Performance P003a-Turbocharger Boost Control Position Not Learned I would check the sensors related to the turbo for loose/damaged connections.
2013 Ford F150 FX4 2006 Chevy Silverado 1500 1982 Chevy C1500 2020 Ford Explorer Limited 2008 Ford Escape |
| Bookmarks |
