60-66 Nut
Re: D52 Caliper Rear Disc Brake Brackets
No, you cannot use the Impala SS rotors with these brackets and the D52 calipers. These are designed to be used with the Astro van rotors which are much thicker than the Impala rotors, and will be the same size as your front rotors. Why do you want to use the Impala SS rotors when they are lighter duty and more expensive than the Astro van rotors?
| Bookmarks |
