Old 07-10-2010, 07:48 PM   #1
edflores
Conversion U-joint. Quick please
Anyone know the part number that would be the one I need? I have a 3 speed manual truck and put a 350 in. The drive shaft uses the small size bearing caps, and the yoke I have , has the big caps. Widths are different too.
Im trying to get it out of the shop by the weekend so an autozone or kragen part number would be great. THANKS!!!
edflores is offline   Reply With Quote
Old 07-10-2010, 07:56 PM   #2
Rich 5150 69
Rich 5150 69's Avatar
Re: Conversion U-joint. Quick please
I belive its a spicer 1350
http://www.dennysdriveshaft.com/p473...e_u_joint.html
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 07-11-2010, 12:13 AM   #3
edflores
Originally Posted by Rich 5150 69 View Post
I think the yoke side ya, but the driveshaft has a different width and cap size.
Old 07-11-2010, 12:29 AM   #4
Rich 5150 69
In that site will give you the measurements for combinations available to you, you`ll have to measure for your needs,
Old 07-11-2010, 01:58 AM   #5
markeb01
Senior Enthusiast
markeb01's Avatar
Napa also sells combination U Joints. You might have more luck finding them locally over the weekend. Here's a link, you just need to know which dimensions you're after:
http://www.napaonline.com/Search/Res...word&Nty=1&N=0
Sorry the link didn't work. Just go to Napaonline http://www.napaonline.com/ and type in "combination u joint". When it asks is this for a specific vehicle answer "no". It will show you the part numbers of the various offerings with the dimensions of the yokes and the caps. If it turns out to be a 1310/1350 combination, the part number is PUJ 348.
Old 07-11-2010, 02:14 AM   #6
edflores
Link didnt work
site keeps acting wierd
Old 07-11-2010, 01:01 PM   #7
padresag
just take what you need into the parts store and have them match it up then. it is common enough
ron
padresag is offline   Reply With Quote
Old 07-11-2010, 01:49 PM   #8
daverod
SSN 706
daverod's Avatar
I was having almost same problem. Now I know what to do. I was thinking I needed a new yolk. I love this place.
daverod is offline   Reply With Quote
Old 07-11-2010, 02:03 PM   #9
edflores
ron
If you know the application it is.
I opened 10 different ujoint at autozone. Nothing had different size caps. One was suppose to but they didnt carry it.
I believe the yoke i am using is too new, and I dont have the matching driveshaft to splice. The yoke side uses the 86ish and newer bearing caps. But the driveshaft uses the older small width and caps.
Thanks for your help guys.
I bought this before from autozone on my first chevy 5 years ago, so I'm sure it existed at one point
Old 07-11-2010, 02:36 PM   #10
daverod
SSN 706
daverod's Avatar
I just checked at Auto Zone the only difference is the cup size. If its a different width your screwed. You can buy a yolk with a different size u joint. I'm just going to have the drive line guy stick a different end on when he cuts mine.
Old 07-11-2010, 02:37 PM   #11
64GMCHorsepower
Justified!
You need the hybrid u-joint, and I believe the 2nd post was right, Spicer 1350......That is what I put on my driveshaft to match to the 10-bolt rear end when I swapped it out....
Call a local driveshaft balancing shop, they should be able to tell you or have what you need to fix it for you.....
Chad
1964 GMC Fleetside Shortbed....350/700R4 tranny
64GMCHorsepower is offline   Reply With Quote
Old 07-11-2010, 02:58 PM   #12
daverod
SSN 706
daverod's Avatar
Two yolks used on a 350 1310 series and 1350 seriers. I don't know which is the big one? New yolk is like $100.
Old 07-11-2010, 03:05 PM   #13
raycow
It might be easier to find a 27 spline 1310 yoke, which will fit both the TH350 and the U-joint in your stock driveshaft. This is a very common part that was used for many years. If your 3 speed manual has a 27 spline output shaft you can use the yoke from that.
Ray
raycow is offline   Reply With Quote
Old 07-11-2010, 04:26 PM   #14
edflores
Ray
That may be what I end up doing. I was trying to get it out asap though.
Thanks for everyones input. I think im going to try NAPA later. I saw some post on other forums with a few part numbers. hopefully one works
Old 07-11-2010, 06:42 PM   #15
padresag
www.neapco.com/n_products-catalogs.php?pdffile=2
this will give you the part nbrs. there is a section on conversion joints. you just have to know dimensions and position of the locks
ron
and if you had found a counterperson with more knowledge then how to use a keyboard they would have given you one
Old 07-11-2010, 09:03 PM   #16
markeb01
Senior Enthusiast
markeb01's Avatar
I just added more information to post #5.
Old 07-11-2010, 09:32 PM   #17
Rich 5150 69
Good job Marked01, memory had failed me agin, my sons dodge has the same.
Old 07-11-2010, 11:36 PM   #18
daverod
SSN 706
daverod's Avatar
Thanks Mark works for me. Headed for NAPA tomorrow. Had one 35.79.
Old 07-12-2010, 02:06 AM   #19
edflores
yeah. Ill try Napa when I get off work. Thanks. Hopefully thats it.
Old 07-12-2010, 04:17 PM   #20
edflores
I went to napa...
Napa customer service was less than helpful so I ended up at a driveshaft shop. I'll grab the PN off the box later but I think I hit the jackpot.
Old 07-12-2010, 05:38 PM   #21
KQQL IT
At the body shop.
KQQL IT's Avatar
Id look at a 1330/1310 u joint. i dont think to many 1/2 tons used a 1350 joint 1310 Series
1 1/16" U-Joint Cup Outside Diameter
3 7/32" U-Joint Width (measured outside-of-cup to outside-of-cup)
External Clips
Side 2:
1330 Series
3 5/8" U-Joint Width (measured outside-of-cup to outside-of-cup)
External Clips
Features: Also from summit Universal Joint, 1310-1330 Conversion, Steel, Each
Product Code: PCN-253
Manufacturer: Precision Universal Joint
UPC: N/A
Condition: New
Precision Super U-joints are precision-manufactured to exacting standards. They have forged and case-hardened alloy steel crosses and heat-treated needle bearings, cold-formed radial bearing cups for 360 degree lubrication distribution, superior quality seals, and a grease fitting in the cross body or end caps for easy maintenance. In addition, the Super U-joints have an exclusive microshield coating to protect against rust and corrosion. They are available in greasable and non-greasable styles.
Old 07-12-2010, 06:37 PM   #22
daverod
SSN 706
daverod's Avatar
I ended up buying the new yoke with the 1350 ujoint insted of getting the combo ujoint. Figured it was stronger. Had to cut about 2" off the yoke to get it to fit right.
