Modifying Suburban doors to fit a pickup
Have any of you swapped pickup door tops (window frames) on to Suburban doors? I have a pair of rust free original 1970 Suburban doors tha I have no use for and my truck needs doors, any help would be appreciated.
PS, Sorry for the double post, I was not paying attention and first posted this in the parts section. Thanks Bill |
Re: Modifying Suburban doors to fit a pickup
I think burb doors are worth a little more than pickup doors. I would have to believe you could make a straight swap, or probably sell them for more than you could get your truck doors for. A lot less work that way.
If you become a subscriber you can post a Wanted to Trade in the classifieds, or even just outright sell the doors.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
Anybody??
Truck doors are easy to find, burb doors are not. I would swap them out for truck doors at the next swap meet and walk away with a little extra money as well. That bieng said if you want to convert the burb doors over then I would drill out the spot welds on the door shell to the outer door channel. If you do that it should pull out. I would practice on the rusty truck doors and see if it will work. I have never done it but if I were to try that is the first route I would try. Good luck!
I don't always drive trucks; but when I do I prefer Chevy's. Stay driving my friends. '72 blazer 2wd build 67-72 Factory Big Block Registry |
Thank you.
![]() Join Date: Nov 2004
Where you're located, I can understand your dilemma. I grew up in NY and a "rust free anything" was hard to find.
Not 100% on this, but as stated above, there should be two spot welds (front and rear) and then there's a bead along the top (again front and rear), drill and grind those out and they *should* come out. Take a close look, you should see what I mean. Mount your doors back on the truck, (take measurements BEFORE you take them out ![]()
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 07-11-2010 at 12:54 AM. |
trucks72
I have swapped the tops before on them. I have on at the shop that I did that to. I will take a picture monday of it. As for the sub door worth more, I could sell 100 truck doors to 1 sub door. There is not alot of demand for them.
trucks72
pictures
Thanks again.
