07-12-2010, 12:29 PM | #1 |
printing is my trade
bed metal thickness question
I'm looking to put down a big metal plate for the bed on my stepper.
Do you guys think I'll need anything thicker than a 11 or 12 gauge plate?
Jojo's '70 stepside build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=344184 |
07-12-2010, 12:38 PM | #2 |
Re: bed metal thickness question
i was thinking about doing that to my truck. When your done post some pics please.
07-12-2010, 01:27 PM | #3 | |
I like this idea better than wood, since I believe it will be more durable and the material is not that expensive. (about $150.00 for the size I need). After some research, I've found that 11 Gauge is a little thinner than 1/8 of an inch. That sounds thick enough.
07-12-2010, 02:19 PM | #4 |
will depend on how much weight is put on it . it will still b very prone to getting sags in it due to no support// in the past i took 1/8" aluminum on top of a 1/2marine plywood that was sealed with undercoating and had no deformation issues with hauling bigblock motors in that bed and all sorts of heavy stuff// got rid of that truck after 25years and the bed floor was still solid and straight just needed a good polishing
one other problem is the width factor// take a ruler to it and then c if you can get a wide enough sheet
71c-10 350/2004r/4:11 lowered3/4 longbed/dead by hurricane MEANING OF DEATH::::: SOMEBODY ELSE GETS YOUR STUFF DONT BELIEVE EVERYTHING YOU THINK TAKE MY ADVISE;I DON'T USE IT ANYWAY Last edited by cdowns; 07-12-2010 at 02:21 PM. |
07-12-2010, 04:08 PM | #5 | |
I also considered welding in my own "ribs" to add strength.. I can definatly get a wide enough piece. The local steel place has 5' X 10' plates and they cut to size
07-12-2010, 04:28 PM | #6 |
thats unusual i could never get more than 48"wide stuuf// you're lucky that makes it alot easier
07-13-2010, 03:06 AM | #7 |
Mine has 1/8" diamond plate welded in, courtesy of the PO. I have hauled engines in it with no apparent damage.
Ray Last edited by raycow; 07-13-2010 at 03:13 AM. |
