Old 05-29-2003, 11:39 AM   #1
6T9GMC
6T9GMC's Avatar
Talking Hey Insane68 Or Lotik
HEY!
HOW DID YOU GUYS MOUNT THE BEDS ON YOUR TRUCKS.....I KNOW YOU GUYS HAD TO CUT SOME OF THE BED OUT FOR YOUR SUSPENSION.... BUT COULD YOU HELP ME OUT A LITTLE. DID YOU JUST PUT A PIECE OF SQUARE TUBING ON THE ORIGINAL STANDS OR DID YOU GO ALL THE WAY ACROSS WITH ONE PIECE IN THE FRONT ONE IN REAR?
THANKS
6T9GMC is offline   Reply With Quote
Old 05-29-2003, 11:45 AM   #2
NSANE68!!!
SLICER AND DICIER
NSANE68!!!'s Avatar
I just used a piece of 1.5" square tubing. I did not run it accross, but that sure would'nt hurt anything even add some bed support.
01 Tahoe 22's 2/4 drop and tv's
68 chevy money pit
51 chevy belair
95 Honda 900RR
05 GMC Siearra (company truck)
NSANE68!!! is offline   Reply With Quote
Old 05-29-2003, 11:52 AM   #3
CPNE
Resident Curmudgeon
CPNE's Avatar
I don't think additional bed support for you guys is needed. From the looks of your projects, you won't be heading to the sand and gravel pit anytime soon!
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 05-29-2003, 12:02 PM   #4
crazy longhorn
Fabricate till you "puke"
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 05-29-2003, 02:22 PM   #5
NSANE68!!!
SLICER AND DICIER
NSANE68!!!'s Avatar
TRUE TRUE!!! , but my bike will be in there when I show. But it's only about 450#
68 chevy money pit
51 chevy belair
95 Honda 900RR
Old 05-29-2003, 03:28 PM   #6
72ChevyCheyenne
72ChevyCheyenne's Avatar
I used 1 1/2" square tubing across the front and fabricated L brackets for the back.
Bill Durham
http://home.attbi.com/~bulldurham
72 Cheyenne
Restoration in progress
Currently: frame sand blasted and powdercoated, Inline Tube brake and fuel lines, Blazer tank in rear, Holley Red electronic fuel pump, Eaton posi with 3.42 gears, 2 1/2" drop front spindles, 4" drop rear springs with adjustable panhard bar, KYB shocks, ZZ 502/502 GM Performance crate engine, Zoops brackets and pulleys, Vintage Air, dual electric fans, Ram Air II hood and late model sport side bed.
72ChevyCheyenne is offline   Reply With Quote
Old 05-29-2003, 06:14 PM   #7
lotik
drag it like you stole it
i put pieces of tubing on the stock mounts.
negative camber //LA\\
lotik is offline   Reply With Quote
Old 05-30-2003, 12:01 PM   #8
6T9GMC
6T9GMC's Avatar
Talking THANKS!!!
THANKS FOR ALL OF THE INPUT! I APPRECIATE IT. ME AND A BUDDY GOT THE BED MOUNTED LAST NIGHT. I STARTED MEASURING AND I NEEDED A LITTLE MORE THAN 1 1/2" SO I GOT SOME 1 3/4" SQUARE TUBING (54" LONG FOR FRONT AND 48" FOR BACK), DRILLED HOLES AND WELDED BOLTS TO LINE UP W/ ORIGINAL FRAME MOUNTS THEN WELDED SQUARE TUBING TO BOTTOM OF THE BED CROSS MEMBERS. (VERY FRONT CROSSMEMBER AND SECOND ONE FROM THE BACK) THE MIDDLE OF THE BED IS RESTING ON THE FRAME SO THAT WAS FINE.
TUBING IS WELDED TO BED WITH BOLTS STICKING OUT TO BOLT TO FRAME... MAKING IT EASY TO TAKE BED OFF LATER. STILL VERY STURDY TOO! THANKS AGAIN. MAYBE THIS WILL HELP OTHERS TOO!
I WILL TRY AND POST PICTURES TOMORROW!
