Closed Thread
Old 07-13-2010, 11:37 PM   #476
07SSSC
07SSSC's Avatar
Re: What did you do to your truck today!
Nothin on the '69, but got the core support pulled off the wrecked '86 burb I picked up a few months back. Part of the accessory drive will probably end up on my '69 so that counts towards this thread, the engine will go into my '84 Trans Am.
'69 Chevy C/10-under reconstruction -- '68 C20 Camper 50th Anniversary-runs, but sorely needs a resto --
'07 Cobalt SS/SC-very fun DD -- '93 Chevy K2500-LQ4/4L80E swap --
'84 Trans Am-awaiting (LS) drivetrain -- '00 Trans Am-road tripper -- '06 Z06-577 WHP beast
07SSSC is offline
Old 07-13-2010, 11:54 PM   #477
bigt76_98
got the '70 out today runnin a little hot in this kansas heat and i think the bearings are goin out in the water pump
bigt76_98 is offline
Old 07-14-2010, 01:40 AM   #478
mgkgmc
mgkgmc's Avatar
Took my bench seat out today to get redone. New springs,foam and material...cant wait to see it finished.
mgkgmc is offline
Old 07-14-2010, 02:07 AM   #479
Tomahawk30
Tomahawk30's Avatar
Installed the new woodgrain dash bezel!
1979 Silverado C10 Shortbox - Photo Album
1977 Silverado K20 Camper Special - Photo Album
1972 C10 Custom Deluxe Highlander - sold
1971 Cheyenne Super Longhorn -sold
1972 Cheyenne Super SWB 4x4 -sold, bought back, sold again... I'm dumb.
1970 Chevy C10 SWB "Sprout" -sold
1972 Cheyenne K20 -sold
1969 GMC Shortbox Stepside 4x4 -sold
1972 GMC Jimmy 4x4 -sold
Tomahawk30 is offline
Old 07-14-2010, 06:03 AM   #480
Shock_Me
Shock_Me's Avatar
Installed a new fuel pump on the Blazer. Pretty simple job
Shock_Me is offline
Old 07-14-2010, 06:59 AM   #481
danielwetpaint
danielwetpaint's Avatar
On my 1974 GMC,, I swapped the 3:73 12 bolt rear end for a 3:31 geared 12 bolt rear end,,plus completely re-did the brakes.
Man what a difference! My little 250 6 cylinder went from buzzin' 3 grand down to a little over 2.
Current ridesne owner GMC 1974 swb, 1986 Chevy lwb,chopped top '85 S-10,1948 Stylemaster rat rod,'2008 Honda Civ.Chopped top '46 dodge.
danielwetpaint is offline
Old 07-14-2010, 12:43 PM   #482
Lippyp
English Chevy Owner
Lippyp's Avatar
As the weather has been too rubbish to finish up the engine wiring I've been ripping off the tints from the windows between rain showers, the side windows were almost limo black, a real PITA to drive after dark and also illegally dark now here so they have to go before I get tugged by Plod and made to rip them off at the roadside. The rear window had only had the two sliding bits tinted and obviously at a different time to the sides as it was much thinner and had gone purple with age and the side windows were not well done and actually had a patch on them. The film came off easily, the glue has used up half a can of cellulose paint thinners so far to remove but it is coming off nicely.
Looked cool when parked up but not worth the hassle.
Phil
'67 C10 long fleet.
350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon
2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission
Lippyp is offline
Old 07-14-2010, 10:54 PM   #483
67Slider
67Slider's Avatar
Finished wiring the engine back in. Bench bled the new MC and repainted my booster cause the old MC bled all over it.
[IMG][/IMG]
Did this a few days ago but it turned out good......
[IMG][/IMG]
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
67Slider is offline
Old 07-14-2010, 10:57 PM   #484
Hubscrub
Cruzin
Hubscrub's Avatar
cleaned up and painted battery tray for the 67
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline
Old 07-15-2010, 12:26 AM   #485
07SSSC
07SSSC's Avatar
Removed the alt and ps pump along with all the associated bracketry and the water pump pulley of the '69. Removed the alt, ps pump, A.I.R. pump, a/c compressor, water pump pulley and crank pulley off the burb. Gonna start mock up tomorrow, gotta figure out a cool/clean way to alter the ps brackets to work though.
07SSSC is offline
Old 07-17-2010, 07:22 PM   #486
Hubscrub
Cruzin
Hubscrub's Avatar
painted my bumper, installed headlight shields and finally painted me a shop logo
Proverbs 3:5,6
Hubscrub is offline
Old 07-17-2010, 08:08 PM   #487
Thealien
Thealien's Avatar
fixed the cruise control/drove it
Thealien is offline
Old 07-17-2010, 08:49 PM   #488
vectorit
What?
vectorit's Avatar
Removed my broken hood latch, then went inside and stared at her from inside.
It's 107 degrees outside right now
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline
Old 07-17-2010, 09:07 PM   #489
treeboy97
treeboy97's Avatar
installed new disk brakes and lowered the front 2 inches and the back 4 inches.
1970 C10 LWB (Grandfather's Truck) 5.3 4L60E
2012 Victory Cross Country Touring
I'm not wasting money on my truck/bike, I'm helping to rescue the economy one mod at a time.
treeboy97 is offline
Old 07-17-2010, 09:24 PM   #490
Rob H.
Rob H.'s Avatar
Today nothing, yesterday I moved the 67 so I could mow where it was sitting and put the rear end down hill so the water would drain from the bed. Unfortuneatly it only moves in reverse. The 72 is still sitting in the same spot with the front wheels off and up on blocks, don't have to worry about it's bed holding water, it's rusty enough to be self draining!
Rob
72 C/10 (under reconstruction)(destruction ? LOL)
48 Willys CJ2A
1952 Super "A" Farmall (Grandfather's)
Rob H. is offline
Old 07-17-2010, 09:28 PM   #491
Shyguy
Junior Member
Shyguy's Avatar
Today, I started the '67 swb stepper and moved it out of the garage so I could work on the ole Jubilee tractor.
I looked at the '71 and said darn one of these days will be your turn.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline
Old 07-17-2010, 09:54 PM   #492
OhioDan
OhioDan's Avatar
Talking Re: What did you do to your truck today!
Finished the interior. Grandson got me a decal for my birthday, so I had to put it on.
LIFE AIN'T EASY WHEN YER FAT AND GREASY!
GMC= Got More Class!
1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started.
OhioDan is offline
Old 07-17-2010, 10:21 PM   #493
yote1234
yote1234's Avatar
got the cab on frame...
1971 K5 CST Blazer
1965 Chevelle Malibu 283 (sadly sold)
1968 Camaro 327
1968 Honda mini-trail z50a #377
1966 uh 1-D Huey
yote1234 is offline
Old 07-17-2010, 10:38 PM   #494
67Slider
67Slider's Avatar
The boy and I put the fan shroud and fan back in,
[IMG][/IMG]
replaced the old MC (no leaks this time),
[IMG][/IMG]
started putting in the B&M mega shifter, Put the driver door back together,
[IMG][/IMG]
DAMN HOT!!!! 103 today in Colorado so I would work a bit and cool off, repeat, repeat and repeat!
Yote1234 - I dig that paint job!!!! Very nice!
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
67Slider is offline
Old 07-17-2010, 10:53 PM   #495
bddcustoms
bddcustoms's Avatar
drilled some spot welds out on the cab -- only had a few minutes to play today.
broke d!@k dog Garage
1969 C20 - Project: "Big Sexy" [http://67-72chevytrucks.com/vboard/s...d.php?t=454894]
2003 'Burban - [Big Pop's daily driver]
1969 350/350 Stingray - [as soon as the economy turns...]
1939 Chevy Roadster Pick Up - Project: "Pre-School" (searching now)
bddcustoms is offline
Old 07-17-2010, 11:05 PM   #496
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
wire wheeled greasy bolts/brackets off gettin' ready for painting sometime soon!
John
1999 Toyota Tacoma 4x4
oldblue1968chevy is offline
Old 07-17-2010, 11:08 PM   #497
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
I swept around the 72 and am doing brakes right now on the blazer..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline
Old 07-17-2010, 11:08 PM   #498
yote1234
yote1234's Avatar
67slider... your looks great also. so you only hit 103? we hit 116 and at 8.00 pm were still over 100 deg. thats hot... again...nice paint..
1971 K5 CST Blazer
1968 Camaro 327
1966 uh 1-D Huey
yote1234 is offline
Old 07-17-2010, 11:18 PM   #499
willys72fleetside
willys72fleetside's Avatar
Didn't have much time but was able to get the seat adjuster wire run from side to side. Every little bit helps!
A USED TRUCK IS A LOVED TRUCK!
willys72fleetside is offline
Old 07-17-2010, 11:27 PM   #500
marks1972
marks1972's Avatar
Took mine to a local Cruz in. Just hapened to drive by it. I didn't even know we had them down here. Come to find out we do every Sat night.
Mark
1968 C-10 SWB 307/munci 4spd/411possi 1986-1990
1972 Cheyenne-10 LWB 350/TH350
IF SHE WHOULD HAVE KEEPT THE SHIRT ON THEY WOULDNT HAVE BROKEN UP THANKS ADAM SANDLER
U. S. Navy Seabee
"CAN DO", "The difficult we do at once. The impossible may take a little bit longer.","We Build We Fight", "Work Hard Play Hard"
marks1972 is offline
Closed Thread
