Old 07-13-2010, 09:36 PM   #1
fire120ball
fire120ball's Avatar
Carpeting a K10
So i bought the carpet kit from brothers which looks great, but i'm not sure what else i need to hold the carpet down. I have no inside trim peices for anything any advice guys? thanks in advance
73 Chevy k10 In progress http://67-72chevytrucks.com/vboard/s...52#post3552552
2000 Trans Am, ls1, 6 Spd http://ls1tech.com/forums/appearance...years-old.html
fire120ball is offline   Reply With Quote
Old 07-13-2010, 10:37 PM   #2
GMC Guy
GMC Guy's Avatar
Re: Carpeting a K10
hey bud, you really only need the sill plates at the edge of the carpet next to the door. other than that, the seat and seat belt bolts will hold it in place. plus a little spray adhesive if you wish. but if you're doing more with your sound system, i'd leave it un-glued so you can route wires under the carpet easier.
http://www.lmctruck.com/features/cc/CCDRB.htm
oh and you can have the sill plates off my old cab, i got new ones
Greg
1974 GMC
1/2 Ton SWB Fleetside
L33 5.3/4l65e
.................__
............._____l __\__
..............l_(O)_ l___(O)]
GMC Guy is offline   Reply With Quote
Old 07-14-2010, 01:48 AM   #3
fire120ball
Re: Carpeting a K10
gregory you are legit!! haha
Old 07-14-2010, 09:58 AM   #4
flamingbig10
6.0 powered square
flamingbig10's Avatar
Re: Carpeting a K10
when your installing the carpet let it sit out in the sun for a few hours to release the box wrinkles and for a easier installation
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 07-16-2010, 04:39 AM   #5
fire120ball
Re: Carpeting a K10
I will do that for sure! thanks Flamin
Old 07-16-2010, 08:57 AM   #6
68 TT
Still plays with trucks
68 TT's Avatar
Re: Carpeting a K10
You can use a scribe to poke through the seat & belt holes from below so you don't cut too big of a hole in the carpet for the mounting bolts. This way they are in exactly the right spot.
Leaving the bolts in the holes is commonly done but can be hard to get the hole positioned just right as the carpet is lifted up at the bolts.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
