07-14-2010, 05:12 PM | #1 |
How would i lower the rear end of my1969 c-10 step side
I wanna lower the rear end of my 1969 c-10 but not sure how
07-14-2010, 05:30 PM | #2 | |
Re: How would i lower the rear end of my1969 c-10 step side
Air suspension? What kind of budget are you working with?
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
07-14-2010, 06:30 PM | #3 |
Nothing to see here.....
blocks and/or drop springs for coil suspension
blocks and/or a leaf removed for leaf suspension air bags and a slew of dohickys for air ride 1000 lbs of gravel
Doug THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten". The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson |
07-14-2010, 07:12 PM | #4 |
Flip kit first before there's a need for blocks.
07-15-2010, 10:50 PM | #5 |
Grandpa in the rustmobile...
were dealing with coil springs most likely, isnt flip kit for leafs..
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
07-15-2010, 11:14 PM | #6 |
1,000 lbs gravel, dude i am still laughing about that one, too funny.
07-15-2010, 11:25 PM | #7 |
Yes, the flip kit is for leafs. These trucks came either way (leaf & coil)....
07-16-2010, 09:18 PM | #8 |
i would like to go static for now i have coils in the rear .
Does anyone have pics of how they lowered the rear with coils? |
07-16-2010, 09:28 PM | #9 |
Look through the various dropped trucks threads from this web-site using this feature http://67-72chevytrucks.com/vboard/search.php.
Pick the amount of drop you like. Buy rear drop coils (or coils & lowering blocks) that equal the amount. Install & enjoy. ECE has a section of their web site dedicated to various drop amounts.... www.earlyclassic.com . . ..... http://www.earlyclassic.com/Tech.asp...=Stance+Photos
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 07-16-2010 at 09:31 PM. |
07-16-2010, 09:37 PM | #10 |
i cant find any installation threads on how to install the blocks with coil suspension
07-16-2010, 09:38 PM | #11 |
Insert Title Here
Mine has a 3 inch spring and a 1 inch block... if you click my pic in my avatar you can see it....its fleet though
BOBBY _69 SWB_ 1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all << |
07-16-2010, 09:52 PM | #12 | |
07-16-2010, 09:57 PM | #13 |
Insert Title Here
Mine is far from pretty under it, but heres my blocks if that helps any
07-16-2010, 10:03 PM | #14 |
ok that looks simple enough thanks 1lo
