No Nonsense
![]() Join Date: Sep 2009
What gear ratio do I have?
Can anyone tell me what gears I am running if I have:
Casting #s Rear Axle: GM14 (full floating) CFD 345 3977323 Front Axle: Dana 44-8F 620121R Transfer Case: NP203 ratio 201 serial 5 20 76 assem no 336990 Running 15/39.5-16.5LT Super Swampers Thanks in advance for any info.
Bi-Centennial Blazer ![]() ![]() |
20' Daredevil (Ret)
![]() Join Date: May 2003
Re: What gear ratio do I have?
Other than pulling the diff cover, counting the teeth and dividing the number on the ring gear by the number on the pinion...
Chock the front tires, jack up the rear end and use jackstands, leave it out of gear and parking brake off. Assuming a pegleg, rotate a rear tire exactly one rotation and count the number of revolutions of the driveshaft. If it's a posi rear, I *think* you double the number (of driveshaft rotations).... or maybe divide by two, I don't recall. Someone will step in and say for sure!
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
If you can get the BOM off the front axle the OEM ratio can be determined from that. It is stamped on the axle tube facing forward just right of the pumpkin.
Tim |
#4 | |
If the wheel is difficult or impossible to turn, you probably have posi. In that case, jack both wheels off the ground and turn either wheel ONE revolution. The other wheel will turn with it. Your axle ratio is once again the same as the number of driveshaft revolutions. Ray |
Kid's Mechanic
The most common gear for a square (from what I have seen) 3/4 4X4 is 4:11,Did you put the super swampers on it or buy it that way?
Best way to know for sure is a tooth count. Last edited by powerdriver 1958; 07-18-2010 at 08:21 AM. |
#6 | |
No Nonsense
Powerdriver, I got the truck with the super swampers on it. She also came with 3 38" Ground Hawg tires that I would like to put on if I could trade these 4 super swampers for 1 more ground hawg..
