C10 CLUB Y QUE!
airbag
Iive notice that my airbag tend to move my pinion angle when i raise or lower it. is this normal for airbags or do i need to move my bags to another location
Re: airbag
There will be some pinion angle change depending upon the total range traveled. Where do you have the bags located? How much travel from full up to completely down?
#3 | |
C10 CLUB Y QUE!
Re: airbag
pinion angle so it would sit at a -7 deg. But when raised it sit at -15 degree bags located over axel. With a bridge Last edited by Sick5; 07-18-2010 at 12:36 PM. |
C10 CLUB Y QUE!
Re: airbag
i have a 4 link no panbar
if a picture would help ill post one i have it sitting on the drive way (up hill) if i rock the truck up hill and then pull down i can see my axel move with the pinion angel. im thinking i need to change the way my upper four links sit so my axel dont rock like that i try to get a video of it and post it on you tube for you guys thanks Last edited by Sick5; 07-18-2010 at 01:25 PM. |
Re: airbag
Yep. Pics are good....
C10 CLUB Y QUE!
Re: airbag
SSN 706
Re: airbag
I think the only angle that matters is the one your at when your truck is at ride height. It doest matter what the angle is when is just sitting on its frame.
C10 CLUB Y QUE!
Re: airbag
with it moving like it does in the video every thing ok
SSN 706
Re: airbag
It will move when you mash on the gas also. If you have your bed off go drive around and watch much the angle changes. Thats why the driveline has a slip yoke in it.
C10 CLUB Y QUE!
Re: airbag
ok i was just worried
