Mike
Brakes!
Do my brakes need bled again,or could it be something else?I have a good firm pedal,the truck stops fine,but while sitting with my foot on the pedal,it slowly goes to the floor.The previous owner put on new wheel cylinders and master cylinder.I put on new rotors,calipers and hoses for inspection.The power booster has been replaced and will hold vacume overnight.This is the first I got the truck out this year.I flushed out all the old fluid.The fluid level does not go down.Thanks Mike
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires |
Sounds like you have an internal leak in your master cylinder.
Yep, first place I would look would be the master cylinder!
Broken Arrow, OK. 1977 Corvette, ZZ4 Crate, new interior, new suspension, new driveline, you get the picture, (new project / daily driver) |
97' Tahoe 2dr/2wd
same as above,
master cylinder |
Mike
Anyone use rebuilt master cyl from autozone?they have them for 17.00 with a lifetime warrenty.At least that's what the counter guy said on the phone.79.00 new at pep boys
97' Tahoe 2dr/2wd
i've used the ones from auto zone before.
they work... a new one would be better, but i don't have the money for a new one either. tommie |
![]() Join Date: May 2002
try looking to see if you have any leaks in the lines anywhere, i had that problem.
Mike 2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip 1972 Chevy Suburban - Turquoise/Black 1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD ![]() Using your turn signal is not "giving information to the enemy" 67-72 FAQ |
I've used AutoZone rebuilt ones & they last maybe a couple of years. No more for me. This was before they had lifetime warranties though.
Mike
Put on a new master cyl. this morning.Took care of the problems.Thanks for the replies!
Red
Just curious.....
Where does the fluid that's leaking go? Mine does the same thing but the pedal doesn't go to the floor. If I sit at a stop light for a while, I have to apply a bit more pressure, to prevent rolling foreward, though. Maybey my leak isn't as bad yet? Mike
'72 Cheyenne LWB 350/350 "The sun don't shine on the same dog's ass all the time." - Catfish Hunter (commenting on why he was not able to pitch another perfect game). |
mike your problem sounds like the booster isnt holding vacumm is the pedal getting hard to push as u sit the or is it sinking
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
Robert Olson Transport
![]() Join Date: Oct 2002
i didnt read the whole thing but MASTER CYLINDER
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
Red
The pedal gets firm as I stop. If I put NO more pressure on the pedal, the truck starts to edge forward VERY slowly. I then put a little more pressure to stop the truck and it doesn't do it again. The truck stops very well when I need it to, (no sponginess or difficulty in stopping). I'll be honest, it hasn't been that big a deal that I've wanted to look into it yet, but when I saw this post it got me to thinking...................
Mike
Mike
On another post about brakes someone said to run the truck,shut it off,and wait 5 min. then pull the vacume line to the booster. you should hear the vacume release if not it is leaking.My master cyl had an internal leak.The pressure would bleed off.
#15 |
Basically what happens when you have an internal leak in your Master Cylinder, is you have a worn o-ring on your piston so when you press on the brake pedal as pressure increases fluid slowly leaks past the o-ring or through groves in the cylinder and goes back to the resorvoir. Then when you release the pedal a vacuum is created in the system and fluid is sucked into the piston as the o-ring passes the pickup hole for the resorvoir. It is hard to explain it, but if you take one apart it is really simple. Everything is held together with a snapring.
