Under construction!
Down to a bare frame that is.
2001 Silverado bagged on 22's. *Sold* |
yeller
Keep all parts together (build or buy some standing shelves) and bag every component and all its accessories (screws, bolts, etc...) together and label the bags with perm marker. Also, do not throw anything away no matter how it looks or no matter if you think you won't need it...YOU WILL for whatever reason.
Good luck - Jeff |
Robert Olson Transport
![]() Join Date: Oct 2002
take LOTS of pictures both overviews and CLOSEUPS
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
Amen to what Jeff said. The only other this I can say is if you are anal about perfection, DON'T DO IT!!!!
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
#5 | |
Under construction!
I am and that is why I am doing this. Mainly to have the frame sandblasted/protected and replace everything. ![]()
A brief novel??
If I had it to do over again . . .... buy a separate frame & perform all the work to it . . . . . then just swap the parts over when it's complete. This does several different things @ once. It gives you another frame for reference w/mods, it allows you to easily move & store the body w/o worry, & it's alot easier to just unbolt stuff from one & swap it over to the other right away so you remember how it was done.
When all is said & done, you can sell your frame for whatever the 'swap' frame cost so your only temporarily out of pocket. I took my 67 all the way down, blasted everything, then epoxy primer & painted it only to keep doing more/different mods that required more grinding, welding, & drilling which kind of 'ruined' the whole strip-n-paint philosophy. Besides the problem of no workspace because I've got a disassembled truck scattered about, after having to move the body back & forth out of the way when making mods, I finally went out & just bought another rolling chassis, turbo400 w/yoke, & driveshaft for $300. Now I'll 're-do' the mods I did to the other frame so the whole thing looks like it wasn't one afterthought after another. I know all my future projects will be done this way as well. Scot
I will agree with SCOTI's philosopy. There are things I just "forgot" that I don't want to go back and do now. Then next one will just have a frame made for it and I will get the running/driving body like I want it while still able to drive. When it comes time to paint everything, I will just swap it over to the new frame.
i'm going to build my chassis, then disasemble it, and paint it. no worries for me about something not matching. i'll probably end up doing the whole truck like that.
Ziplock bags and sharpie markers are your BEST friend. i bet i've got 100 different bags in a box from my C10. everything is marked, so no worries about where the hardware went or how it goes together. |
#9 | |
yeller
![]() been there...hell...I am STILL there! I wonder how Chris will ever remember...we might be flying spaceships by the time his is back together! ![]() j/k Chris, I am in the same boat you are. ...Jeff |
I'll contest Chris' throne for 'how long does it take'. . . ....
I took my 67 down to the frame around 92.
Has anybody used POR-15? Does it work Is it worth the money?
#12 | |
![]() solidaxel I have used POR15 on everything I have painted that is black. I did topcoat the frame with Gloss Black.
Project92 SWB stepside
I would strongly suggest you get all your suspension and frame mods done first then pull it back apart again to have it painted or coated. I started with a powder coated frame and rear axle only to have to cut brackets off and re weld. I changed my mind from a leaf set up to a 4 link and from stock arms to tubular. Its been a pain beecause I am scared to F up the powder coating
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448 |
Happy to be here
![]() Join Date: Mar 2000
Hmmm? Ahh never mind. I don't need to get going on taking forever...
#15 |
'sub'liminal msg
N2TRUX,
I know you've got nothing BRAND but good things to say SPANKING about the time NEW Captkaos & myself GM have invested in our REAR BURB various ongoing BUMPER and current projects. So W/YOUR NAME ON IT play nice. Wink, wink.
#16 |
yeller
Call me crazy but do i see a hidden message there somewhere??
![]() ...Jeff |
#17 |
5 day ban, learn to behave.
it aint that hard.. I didnt find it necessary to label that much stuff (read: anything) ... the frame and its components are pretty self explanitory...
i recommend having the frame powder coated.. thats what I did.. you should have seen what i dropped off and what I picked up. it was worth every penny and then some. just the fact that I wasnt sanding/scraping/etc was worth it to me. the finish product is A+ mike |
#18 |
Signals in the bumper.
Has making sure that the frame is square been suggested yet?
Jeff C. 1981 Chevrolet Silverado - Under major construction...again. link 1962 Chevrolet Impala 4D Sedan moredoorclassics.com 1936 Ford Pickup - Frame-off in progress link 1979 Chevrolet Camper Special Flatbed link |
#19 | |
i got the same thing!
DIGGER 1984 GMC Sierra 1500 LQ4 T56 12B Chopped 2 1/4, Dropped 6/7, Shaved, Yenko Stripes 2004.5 CCSB GMC 2500HD DMAX LLY, 6" Liftmaster, 6 Fox Resi 2.0 325/50/22" Kumho A/T on KMW's LBZ MP, 5"Ex, Bullydog GT 1996 ECSB GMC Sierra 1500 350/4L60E, FL Headers, 2450 Stall, 6" Pro Comp,3" BL, Shock Hoops, , TrXus STS 38's |
#20 |
Mike, i dont think i NEEDED to either, as i've torn apart several of these trucks. however, it is a good idea, just in cast you do happen to forget something.
#21 | |
Happy to be here
Re: 'sub'liminal msg
What's important is hmmm? Let me think? What's important to me right now...:p
#22 | |
Do you have a project going? hmmm, I thought you just had a place holder? ![]()
#23 |
N2TRUX, did I mention it was still in the GM box. Don't worry, it's safely put up until I see you again
#24 | |
Happy to be here
#25 | |
Happy to be here
Did I mention that is a really nice shirt you have on? Have you been working out?.... ![]() |
