Old 04-23-2010, 09:09 PM   #26
EVBuilder
EVBuilder's Avatar
Re: F word project stands in the way.
I thought I would throw some more picture up on frame repair where the body mount bolts go though. The picture of the piece laying on graph paper is what the hole looked like when I started. Each of those squares is 1/4". The last picture is the two crossmembers standing next to each other, not sure if you can see light around the mount holes or not from that angle.
EVBuilder is offline   Reply With Quote
Old 04-25-2010, 04:12 PM   #27
EVBuilder
EVBuilder's Avatar
So I have found two different kinds of Peeps. Which one would looks better on there?
Old 04-26-2010, 06:54 PM   #28
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
I like the bottom one cause everyone has the short arm version.
Old 04-26-2010, 07:00 PM   #29
EVBuilder
EVBuilder's Avatar
I like it too but my daughter likes the short ones better. Being its her truck I guess I have to with her choice. There have been a few things that have sidetracked this project for a bit. One the rear axle in my 63 blew up and needed an overhaul. Two the son inlaws 2000 truck broke a leaf spring and took out a brake line. Three the same truck lost a driver door window. Four daughters friend blew up the transmission in her Civic and wants me to fix it. At least two of the four are done now. Still have to get the other two done.
Old 04-26-2010, 07:07 PM   #30
aerotruk63
aerotruk63's Avatar
One thing at a time, there`s always tomorrow. I look at it this way, no one never has the time to do something, they just don`t want to be doing it right now or they would push aside everything else to accomplish the task.
Old 04-27-2010, 10:30 PM   #31
EVBuilder
EVBuilder's Avatar
I thought I would throw a picture of the rebuilt rear axle for the 63 GMC that has been part of the delay in getting back to the BroncoII project.
Old 04-28-2010, 05:56 PM   #32
EVBuilder
EVBuilder's Avatar
Just a quick update but no pictures. I managed to do something on the Bronco today. I have the top half of the gas tank painted with Eastwood rust encapislator. I also tacked the filler panel for the passenger side door handle. I still have to finish welding that then make and weld the lock hole filler. Then fill all 8 mirror mounting holes. Then I am going to do some custom touches for the bumpers. I want to make them fit the body a bit better and plug weld the bolts in so they look smoother and paint them body color.
Old 06-25-2010, 09:08 PM   #33
EVBuilder
EVBuilder's Avatar
It has been a while since I have posted anything on this project. The truck had some road worthy issues that had to get sorted out.
So I have both doors finished now with all the welding and filling. Sanding is nearly done then cleaning and the high-build will go on first part of next week then after blocking It will be time for color. I am really looking forward to getting paint on it. I will post some pictures this weekend of what I have done so far and then more after primer is on.
Old 07-01-2010, 09:44 PM   #34
EVBuilder
EVBuilder's Avatar
Finally something new to report with pictures. I have the Bronco in primer. I sprayed the high-build epoxy today and started to block. Here are a couple of shots that show the lack of handles and excess holes. I will post more tomorrow. I am hoping to get the blocking done then and maybe be able to to get the first part of the color on. which will be the secondary color in the middle which is 1969 AMC Big Bad Blue.
Old 07-02-2010, 08:19 AM   #35
EVBuilder
EVBuilder's Avatar
Here are a few more pictures. the last one is the epoxy primer I used. It is a 2K product that is direct to metal and can be mixed to use in different ways. I mixed it straight 4 to 1 to use as a high build. add some reducer for a standard primer.
Old 07-02-2010, 08:59 AM   #36
OARNGESI
OARNGESI's Avatar
trucks looking really good is your daughter starting to get excited
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 07-02-2010, 10:05 AM   #37
EVBuilder
EVBuilder's Avatar
She is getting very excited. I am too because this means I can get the 1962 Tempest in the shop and get the concrete put down on the upper half of the driveway.
Old 07-02-2010, 03:00 PM   #38
EVBuilder
EVBuilder's Avatar
The Big Bad Blue is done. Now that there is a shine on it you can really see my lack of body work skills. But as they say you only get better with experience. Maybe the next one will be better.
Old 07-05-2010, 09:47 AM   #39
EVBuilder
EVBuilder's Avatar
Sprayed the final color on Saturday. I will be putting wheels back on today and taking more pictures with all the tape off. I still have the bumpers and the window trim to finish before i can get assembly done.
Old 07-05-2010, 02:34 PM   #40
HeavyD
HeavyD's Avatar
Well it looks 100x better than when you started. Nice choice of colors too.
"You can take the man out of PA, but you can't take PA out of the man"
HeavyD is offline   Reply With Quote
Old 07-06-2010, 06:46 AM   #41
OARNGESI
OARNGESI's Avatar
Thats going to look really good all together
70 SWB STEPSIDE
70 BLAZER
09 challenger
Old 07-06-2010, 04:57 PM   #42
robb67
robb67's Avatar
Looking good man, I'll have to come over for a look in person 'cause I can't see anything wrong with the body work. Nice ride for the daughter....lucky girl.
robb67 is offline   Reply With Quote
Old 07-07-2010, 11:30 AM   #43
EVBuilder
EVBuilder's Avatar
I thought I would post one of the things that went wrong and maybe someone else will learn from my mistake. Above on this page there is a picture of the epoxy primer I used on this Bronco. Shortly after I bought it the can was knocked off a bench while I was out. when I came back there was a puddle on the floor. I was upset that I lost some primer but didn't think anything more about it. When I opened the can to use it I discovered there was about a quart gone. What I didn't realize was that what leaked out was the oils in the paint leaving the the paint solids still intact. So when i activated it as per the instructions it was far too thick and the pot life reduced. It sprayed so poorly that it took over 2 hours to get one coat on. By then the paint was curing in the can making it even thicker. So consequently I was only able to get half the gallon on the truck making blocking nearly impossible. So what would have been sanded straight and smooth was rough and the body work shows way more than I thought it should. Live and learn as they say. Keep your paint products in a safe place.
Old 07-07-2010, 11:42 AM   #44
EVBuilder
EVBuilder's Avatar
So here are some pictures of the truck with the wheels and some of the exterior parts installed.
Old 07-10-2010, 09:55 PM   #45
EVBuilder
EVBuilder's Avatar
The Bronco is on hold for a week or so yet again. I got the green light to get the top portion of the driveway concreted. So I spent all day on the Bobcat grading and hauling dirt one bucket at a time a block away. I did manage to get most of it done so it should go quickly tomorrow. Then hurry up and wait for the finisher to get some free time to pour it.
Old 07-10-2010, 11:10 PM   #46
67ChevyRedneck
67ChevyRedneck's Avatar
Not too shabby I like the color scheme!
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 07-20-2010, 09:13 PM   #47
EVBuilder
EVBuilder's Avatar
Here is what put the Bronco on the back burner for a while
Old 07-20-2010, 11:21 PM   #48
robb67
robb67's Avatar
Nice concrete pad ya got there.....I think it'll look great with your '63 on it!
