Re: Help
I dont have a scanner but I am sure I can find one. I assume when you say CTS you are referring the the coolant temp sensor? Which I just got from GM yesterday and installed last night along the the MAP sensor do I need to unhook my batteries and reset the computer after having installed these two sensors? When you say IAC what are you referring to? Could it have anything to do with the EGR valve?
"WIDER IS BETTER" (TRUCKS ONLY) |
| Bookmarks |
