Old 07-22-2010, 08:12 PM   #1
68black_betty
68black_betty's Avatar
opinions on carb and intake manifold
im lookin into to getting a higher performance carb and intake for my 68 c10 with 454, ive been lookin into the holley 750 and the edelbrock performer intake, im just lookin for some opinions and advice on what carb and intake would be better performance wise
68black_betty is offline   Reply With Quote
Old 07-22-2010, 08:39 PM   #2
68black_betty
Re: opinions on carb and intake manifold
also recommendations for a bigger cam
Old 07-22-2010, 09:06 PM   #3
capev86
carb: a 750 holley is NOT an improvement over a good old q-jet (also a 750). GM ran them on all their top muscle cars back in the day. you can't beat the balance of efficiency and power that comes from a spread bore design. only thing out there that is better is a nice fuel injection system.
intake: remember that big blocks are low rpm motors and like a daily driver, do not benefit from an intake tuned to start developing power at higher engine speeds.
cam: roller valvetrain is the smart way to go....less valvetrain wear and tear and less power bled off as friction. another piece you will want to benefit the idle - 5000 rpm range on a street truck.
capev86 is offline   Reply With Quote
Old 07-22-2010, 10:06 PM   #4
red69ss
Burnouts are therapeutic
red69ss's Avatar
you are going to get a bunch of different opinions on this subject its one of the most colorful subjects I've seen discussed here. In my experience I have had the best luck with holleys they are pretty simple to work on and tune as I am no carb tech. I love the sound of a quadrajet being opened up , but in my experience they are not novice friendly , I've had a couple rebuilt and never felt like I had them tuned right( never tried one of the factory rebuilt ones) , most the new carbs( holleys and edelbrocks) are pretty much bolt on and go. not a big fan of the edelbrocks but a lot of guys love them. I have a holley 750 on my 454 and it performs well, this is a tough decision to make good luck
1969 CHEVELLE SS
1972 C10 ALMOST DAILY DRIVER
1968 C10 RUSTBUCKET (MISSION IMPOSSIBLE)
1972 PONTIAC LEMANS CONVERTIBLE (WIFE'S CAR)
"My wife and I were happy for twenty years. Then we met." - Rodney Dangerfield
"The difference between genius and stupidity is that genius has its limits." - Einstein
red69ss is offline   Reply With Quote
Old 07-22-2010, 10:58 PM   #5
1969stepside
1969stepside's Avatar
air gap and qjet
Greater love hath no man than to lay down his life for a friend.
Members i Have met
Earl Slick68
1969 Stepside Build thread
http://67-72chevytrucks.com/vboard/s...=1#post4253546
Chevy Trucks the longest lasting most dependable trucks on the road
1969stepside is offline   Reply With Quote
Old 07-23-2010, 02:16 AM   #6
tkeduk8r
tkeduk8r's Avatar
"air gap and qjet"
ditto!!!!
--Mike
63 C20 2WD, 230/SM420/4.11 73K
68 C30 dump truck, 327,SM425,4.56 66K original
68 C10 2WD SWB Stepper, 250/3-tree/3.73 66K.... Wifes
68 Buick Skylark Custom Conv., 350/TH400/2.56 In our family since '79
69 GMC 1500 SWB 2WD, 350/TH350/3.73 posi...
70 K10 SWB 4X4 4-sp,ps, pb, tilt, buckets, console, sliding back window (Need AC parts) WIP
72 Chevy K20 4x4 350/350/205/4.56 donor
72 Vette 350/M21/3.70 posi, triple black and super fast
84 Olds Cutlass Brougham 350/2004r/4.11 was Dad's
tkeduk8r is offline   Reply With Quote
Old 07-23-2010, 07:57 AM   #7
68Stepbed
68Stepbed's Avatar
I agree with the Q-jet being better, but if you do want to run a Holley, a 750 may not be the best size. Look into the 650 cfm range. The smaller cfm will give you better throttle response, better driveability, and actually, more horsepower.
After you pick your cam and intake, figure out what heads you have and the specifics on them. Then call somebody like The Carb Shop or QFT and they'll actually match a carb to what you have.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 07-23-2010, 08:24 AM   #8
cdowns
cdowns's Avatar
i like multicarb setups// i'd go twin carbs on a midrise manifold on a bigblock// alot depends on specs
without knowing specs a cam suggestion is useless// i spend lots of time with companies on thier tech line doing research to pick a cam to work properly in my applications
Old 07-23-2010, 09:17 AM   #9
marks1972
marks1972's Avatar
i agree with Cdowns on the cam. call tech lines. give them your specs and let them know what you are looking for out of your engine (performance-vs-rpm range). they can also assist you on the intake and carb size for what you are looking for.
carb brand is up to you.
me personally i perfer the edelbrock.
edelbrock - better for cruzen - a little harder to adjust but once it is set it is done.
Holly - better for racing - easyer to adjust out but one backfire and you are off to the store for anotherone.
qjet - if you have someone that is knows them well and is good with them you cant beet em however if you dont you will be fighting with them contently they are tempermentaly and dont like it at all when someone touches them that dont know what they are doing.
these are all just my opinions though.
Mark
1968 C-10 SWB 307/munci 4spd/411possi 1986-1990
1972 Cheyenne-10 LWB 350/TH350
IF SHE WHOULD HAVE KEEPT THE SHIRT ON THEY WOULDNT HAVE BROKEN UP THANKS ADAM SANDLER
U. S. Navy Seabee
"CAN DO", "The difficult we do at once. The impossible may take a little bit longer.","We Build We Fight", "Work Hard Play Hard"
marks1972 is offline   Reply With Quote
