Old 07-23-2010, 05:30 PM   #1
Sven
Sven's Avatar
Windhield washer bottle questions
I have a 69 4x4 and it's missing it's washer bottle and I can't find the wiring under the hood or where the washer bottle would go. I'm betting it got buried by the PO.
I'll buy a bottle and pump and hose from LMC or something, but does anyone know where the bottle goes and what the wiring is for the pump so it'll work from the washer switch inside the cab?
-Steve
1969 Chevrolet 4x4 C10 Pickup
Sven is offline   Reply With Quote
Old 07-23-2010, 05:35 PM   #2
Sinister
Between Trucks...
Sinister's Avatar
Re: Windhield washer bottle questions
12 volts key on to the red wire for the pump, I ran from the wiper motor for this. Ground wire from the pump to the middle connector at the wiper switch, (blue factory wire goes to this connector). I went to pick a part and got a washer bottle out of a sedan that mounted up to my drivers side inner fender.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 07-23-2010, 05:51 PM   #3
cdowns
cdowns's Avatar
the stock pump is up under the dash in the drivers comp attached to the wiper motor. the bottle mounts on the driver side inner fender the pump sucks the fluid from there and squirts it on the windshield
PUMP IS NOT ATTACHED TO THE BOTTLE in a factory setup
Old 07-23-2010, 05:55 PM   #4
Sinister
Between Trucks...
Sinister's Avatar
This is true. My instructions are for an aftermarket washer pump.
Beat it to fit,
Old 07-23-2010, 06:04 PM   #5
LockDoc
The Older Generation
LockDoc's Avatar
Here is another thread on the subject...
http://www.67-72chevytrucks.com/vboa...d.php?t=217477
LockDoc
Leon
Old 07-23-2010, 07:22 PM   #6
swierker
swierker's Avatar
The stock pump is a real PITA to get to. Instead of replacing it I used a universal pump and mounted it to firewall. I ran the positive and negative wires from the stock connector I removed from the old pump.
swierker is offline   Reply With Quote
Old 07-24-2010, 01:07 AM   #7
68 TT
Still plays with trucks
68 TT's Avatar
A great bottle & pump to use is the 88-98 new body style truck setup. The tank holds nearly a gallon of fluid, the pump is electric and tucked nicely behind the bottle out of sight and they are easy to get. I just got one today for $4 to put on my 67.
I already put one on my 78 to fix a defective stock on-motor washer pump and broken aftermarket external electric pump.
http://67-72chevytrucks.com/vboard/s...4&postcount=11
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 07-24-2010, 02:34 AM   #8
Sven
Sven's Avatar
Just the ticket, boys, thanks a lot. More than enough information to work this out now. That 88-98 bottle looks just the ticket ...
-Steve
