Old 07-05-2010, 08:43 PM   #1
Guy58
Smile Bed Angle Pieces
I am currently taking the wooden bed out of my 67 stepside. Everything was going good untill I tried to remove the two angle strips at the sides. I have all of the screws out from the bottom and the stripes in the middle just came right out.
What am I missing? Do I have to take the back fenders off, are there screws holding the angle pieces to the sides of the bed that can't be seen?
Need help,
Thanks,
Guy
Guy58 is offline   Reply With Quote
Old 07-05-2010, 09:07 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Bed Angle Pieces
I believe they are spot welded to the bedsides.
Keith
Convert to disc brakes.
Old 07-05-2010, 09:44 PM   #3
69c10step
69c10step's Avatar
I agree...i beleive they are welded on.
'69 short step with dreams of being a hot rod
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
69c10step is offline   Reply With Quote
Old 07-05-2010, 09:46 PM   #4
tcb-1
Nothing to see here.....
tcb-1's Avatar
confirmed. welded
Doug
THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten".
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
tcb-1 is offline   Reply With Quote
Old 07-06-2010, 10:10 AM   #5
Guy58
Thanks guys,
Went and got a couple of grinding wheels for the drill. My idea is to grind down untill I can locate the welds and than drill them just enough to make them release. Most are hinden under the rear fenders so I may be able to pull this one of.
Guy
Old 07-06-2010, 10:15 AM   #6
FL71C10
Do you think you will have to take the fenders off? I am looking to do the same thing and don't want to take the fenders off.
71 Chevy C10 Shortbed Stepside. LT1 with
4l60E. Just got back from painter, in assembly now.
FL71C10 is offline   Reply With Quote
Old 07-06-2010, 10:22 AM   #7
gkesseru
gkesseru's Avatar
They are welded every 3 inches. I use a 4" electric angle grinder and it is still a bear to grind all of them flat.
See this thread for finished stainless replacement.
http://67-72chevytrucks.com/vboard/s...d.php?t=404835
72 Fleet (died)
78 Step (sold)
55 Step named Fred (sold)
00 F150
68 Step (named El Scorcho by PO)
Build thread for the new El Scorcho http://67-72chevytrucks.com/vboard/s...d.php?t=392932
gkesseru is offline   Reply With Quote
Old 07-06-2010, 06:21 PM   #8
Guy58
Hey Everyone,
I have one angle strip out and all of the other wood except the other angle strip on the passengers side.
It's has been easy. I started yesterday and have done ok so for.
I built two blocks the same height as the front two braces and bolted them in place to support the bed's front body panel and bolted the back end one bolt on each side.
I'm going to restore the frame under the bed now that it is open and easy to get to.
My wood is teak. I ordered 'Sikkens Cetol Marine Gloss' yesterday. I'm going to get the other angle strip out and get my wood ready to refinish.
Don't you just love it!
Guy
Old 07-08-2010, 07:57 PM   #9
Guy58
Smile Re: Bed Angle Pieces
Here are a few of the frontend.
Old 07-08-2010, 07:59 PM   #10
Guy58
Here are a few of the bed work in progress.
Old 07-12-2010, 09:28 AM   #11
Guy58
A word to the wise, if you are planning to replace the angle pieces in your wooden bed. The two right angle strips have tack welds most of the way along the angles. But the 6 to 8 inches closest to the the truck cab have a straight weld and must be cut free. I used a cuting wheel but the heat burnt the paint on the outside of the bed between the rear fender and the front of the bed. This turned out to be a more difficult project than I had anticipated.
Just a heads up for some of you,
Guy
Old 07-12-2010, 03:34 PM   #12
Guy58
Got the other angle piece cut free and went down to the local high pressure car wash. Cleaned my frame up and am waiting for Eastwood's rust encapsulator to refinish it. After I get the frame it will be back to the bed refurbish project. Funny how one thing can lead you down roads you hadn't even thought of!
Guy
Old 07-24-2010, 11:09 AM   #13
frmula505
frmula505's Avatar
The angles I used just clip over the old one and bolt on. That was the best way to go if your building a driver.
1961 GMC Suburban Custom
1969 Short wide project http://67-72chevytrucks.com/vboard/s...d.php?t=535479 (SOLD)
1959 Apache fleetside (frame off in progress) http://67-72chevytrucks.com/vboard/s...d.php?t=348746
1960 Apache short/narrow shop truck http://67-72chevytrucks.com/vboard/s...d.php?t=350780 (SOLD)
1951 Plymouth leadsled project
2005 Corvette conv. Procharged
1969 Corvette stingray
2006 Cadillac XLR-V
1950 Oldsmobile 98 custom project
frmula505 is offline   Reply With Quote
