07-23-2010, 06:07 PM | #1 |
Phoenix Systems Reverse Brake Bleeder
Found this looking for some info on bleeding brakes, looks pretty cool, anybody ever tried one before? http://www.brakebleeder.com/index.ph...products_id=16
'68 C10 LWB 6.2NA/NP833 3.73's |
07-23-2010, 06:09 PM | #2 |
Gearhead
Re: Phoenix Systems Reverse Brake Bleeder
I havent personally, but Stacey David (Gearz TV) swears by them, I was going to look into one the next time I do any major brake work to the trucks...
2002 Saturn SL2, My D/D 2019 Ford Fusion SE, Ecoboost - Wife's D/D 1993 Camaro Z28, A4, CAI, Cat-Back Exhaust Project C10 (my 72' C10 w/96' LT1, 700R4, bagged F&R, 18's (for now), Short/Fleet) -- SOLD! Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=313644 |
07-23-2010, 08:04 PM | #3 |
Its a Truck Thing......
DONT waste your money, I bought one and its all plastic,the connectors stripped out the first time I used it.....I thought the same thing, must be good if Stacey liked it.
Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 71 C20 Longhorn/Ole Yellor 69 C30 Former Motor Home, Flat Bed time |
07-23-2010, 08:43 PM | #4 |
Truck and auto performance nut
Hey....he too has to sell commercial space!
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
07-23-2010, 09:16 PM | #5 |
i dont buy stuff because billy mays ,vince or stacey have infomerrcials on something
been doin just fine steppin on a pedal and crackin open bleeder screws for 40-50 years
07-24-2010, 12:23 AM | #6 |
I think they have a $300 one, it's the one stacey david used
07-24-2010, 09:56 AM | #7 |
I've had good luck with the "dorman" one man or speed bleeders. They are just odinary looking bleeder screws with a little ball & spring assy. Inside that acts as a check-valve. (they're $10 for a packet of two) they work great for me as i find myself alone most of the time when it comes to brake bleedeing. You just put a little dialectrioc sylicone around them, crack em loose, pump all you need to & the air & fluid can come out, but nothing goes back in. Work great for me. john
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES// LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
07-24-2010, 10:39 AM | #8 |
Active Member
Yikes! $80.. As infrequently as I bleed the brake systems on my vehicles, I'll stick to the old way. Takes me about 30 minutes with the help of my wife.
07-24-2010, 10:49 AM | #9 |
Between Trucks...
I use a $5 one man brake bleeder kit I got at Kragen. Little bottle with a magnet and some tubing. Now I don't need my girlfriend to help bleed the brakes.
Beat it to fit, Paint it to match... |
07-24-2010, 10:59 AM | #10 |
Active Member
Send more info... What is Kragen and what part is it? Wife gets antsy when I ask her for help these days...
07-24-2010, 11:01 AM | #11 |
Between Trucks...
Kragen is like O'Reillys. Here's a link: http://www.google.com/search?hl=&q=o...+brake+bleeder
07-24-2010, 11:40 AM | #12 |
one man brake bleeder kits are lame// all you need is a cement block or heavvy toolbox and the imagination to put it to work for you
07-24-2010, 11:43 AM | #13 |
Between Trucks...
Meh, mine was only $5 and it works.
07-24-2010, 12:19 PM | #14 | |
Smitty
07-24-2010, 12:47 PM | #15 |
Moderator
I use a Mighty Vac. $30 at Harbor Freight. It not only makes brake bleeding a snap, but has a ton of other applications as well.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
07-24-2010, 02:11 PM | #16 |
this is what i've been using, plus i have speed bleeders like john was talking about. works great.
http://www.harborfreight.com/brake-f...der-92924.html
1970 GMC 4x4 swb fleetside custom 4 inch lift with rear shackle flip, mild sbc, tci trans, rebuilt np205 w/twin shifters |
