Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 07-23-2010, 12:43 PM   #1
J_PEPIN87
J_PEPIN87's Avatar
Transmission cross member
Well i got the big block installed in my truck and everything lined up pretty good.yesterday i installed the pass. Side header, i used the 2455 hooker comps, and it went in ok but the problem is that the collector sits about half way on the trans cross member.wat do yal guys think i should do about this?
J_PEPIN87 is offline   Reply With Quote
Old 07-24-2010, 11:56 AM   #2
68longhorn
68longhorn's Avatar
Re: Transmission cross member
What do you mean on? on my caprice the crossmember went right behind the collector so I couldn't add exhaust. I put on a double hump crossmember from g-force.
68longhorn is offline   Reply With Quote
Old 07-24-2010, 02:51 PM   #3
KQQL IT
At the body shop.
KQQL IT's Avatar
I built one from 3/4 ton with out a cat. Notched the center for the mount.
Old 07-25-2010, 12:58 AM   #4
J_PEPIN87
J_PEPIN87's Avatar
My cross member is right behind my collector too and about half way on the collectors,looks like ima have to notch the cross member to clear the exhaust I plan on running 3 in exhaust
Old 07-25-2010, 01:01 AM   #5
J_PEPIN87
J_PEPIN87's Avatar
Dat looks good I think ima just have mine notched
Old 07-26-2010, 10:44 PM   #6
69trk
69trk's Avatar
I ordered one from transdapt. Worked great...
http://67-72chevytrucks.com/vboard/s...d.php?t=494388
431 big block times, changed to a 6.0 ls with turbo
1.58- 60'
7.18- 1/8th mile@95.18
11.37- 1/4 @115.81
69trk is offline   Reply With Quote
Old 07-28-2010, 06:30 PM   #7
J_PEPIN87
J_PEPIN87's Avatar
Originally Posted by 69trk View Post
i ordered one from transdapt. Worked great...
do you have the part number for this one. I checked them out online and the prices are not bad at all i think i might go with this one.did you have to weld the ends of it?
Old 07-28-2010, 08:04 PM   #8
69trk
69trk's Avatar
I'm trying to find the part number for you. I can't seem to find the receipt, which i have every receipt for the last 20 years on this truck... What i did was measured inside to inside on the frame, then found that piece on transdapt website. Yes, the ends i welded them on. I bolted the crossmember to the trans, then adjusted the ends, marked them, tacked them in place, then welded them up and shot them with some primer and black paint. Make sure you have the trans set where the original crossmember held it.. I ordered it thru summit racing or jeggs , they don't show them in their catalog..
1.58- 60'
11.37- 1/4 @115.81
Old 07-28-2010, 08:22 PM   #9
J_PEPIN87
J_PEPIN87's Avatar
Thanks! I just went straight to their website.how much did you pay for yours?is yours the 3in. Drop member?
Old 07-28-2010, 08:44 PM   #10
69trk
69trk's Avatar
I can't remember what i paid for mine, but i do think they were cheaper thru summit and jegs. And yes it was a 3" drop..
1.58- 60'
11.37- 1/4 @115.81
Old 07-28-2010, 09:12 PM   #11
J_PEPIN87
J_PEPIN87's Avatar
Ok I'll check them out on summit.
Old 07-28-2010, 10:03 PM   #12
ripdog28
ripdog28's Avatar
I have the same as 69trk. about $50 or 60
69 c-10 BBC
462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build.
ripdog28 is offline   Reply With Quote
Old 07-28-2010, 10:09 PM   #13
J_PEPIN87
J_PEPIN87's Avatar
Damn that's not bad at all, wat about the mount is it a regular mount?
Old 07-28-2010, 11:14 PM   #14
69trk
69trk's Avatar
stock mount
1.58- 60'
11.37- 1/4 @115.81
Old 07-29-2010, 12:16 AM   #15
J_PEPIN87
J_PEPIN87's Avatar
Do the ends of the crossmember lay flat on the bottom part of the frame?
