Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 07-11-2010, 07:24 PM   #1
dammitmitchell
the pollock
dammitmitchell's Avatar
motor pull on a 98
hey gents gotta pull and replace the motor on my 98 blazer.
question of the day is
pull motor tranny out as a whole?
pull motor seperate from tranny?
do i need to pull the radiatior support to get this little bugger out?
thanks!
any heads up is appreciated. I feel i need the hands of an oriental woman to work on this thing.
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
Old 07-12-2010, 06:22 AM   #2
68C15
blood type; Retumbo
68C15's Avatar
Re: motor pull on a 98
leave the tranny and rad. support.
this is pretty straight forward aside from the 2 upper bolts on the driver's side of bell housing. I have found it easier to remove the steering intermediate shaft and lift body 2 or 3 inches.
another thing that makes it easier is to remove engine wiring harness from under the fuse block and lay it all over the pass. fender.
why the motor pull?
68C15 is offline   Reply With Quote
Old 07-12-2010, 04:35 PM   #3
dammitmitchell
the pollock
bad motor no compression.
Army vet 02-08
Old 07-20-2010, 12:48 AM   #4
lvschevytrucks
Unfinished Project Club
lvschevytrucks's Avatar
Check out the build on my 95, Blazer, its not to bad if you lift the body.
Handle every Stressful situation like a dog.
If you can't eat it or play with it,
Pee on it and walk away.
1996 Dodge Intreped ES Nice car great on gas
1993 Jeep Cherokee.
Looking for a swb chevy 73-87
lvschevytrucks is offline   Reply With Quote
Old 07-20-2010, 12:02 PM   #5
truckdude239
truckdude239's Avatar
well if it is anything like the 2.8 i did in our company blazer (1988) i removed the front 6 mounts used the lif tot lift the body and put a 4x4 block under the 2 mounts at the doors. pulled the tranny then the motor
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 07-20-2010, 03:55 PM   #6
lvschevytrucks
I did the same thing but without removing the tranny
1993 Jeep Cherokee.
Old 07-21-2010, 06:52 AM   #7
truckdude239
well we replaced the tranny and motor
David fuller
2000 Tahoe 5.3l 378
Old 07-25-2010, 04:24 PM   #8
Damien
Damien's Avatar
I have found it easier to pull the trans with the engine on 2 wheel drive trucks atleast. The body can be left alone
I can still count my vehicles on two... wait three hands.
Damien is offline   Reply With Quote
