Old 07-25-2010, 01:07 PM   #1
GmtGmt
Conversion Truck Addicted
GmtGmt's Avatar
6 Inch Lift kit K5 Blazer
Well a freind of mine wants to get his stock 83 K5 lifted.
he wants a 6 Inch Lift kit under it.
anyone know an online shop thats sell a good kit with everything thats plug and play.
Been looking at this
http://www.roughcountry.com/chevy_4wd_77-87_6.html
the blazer is a stock 83 K5 Blazer Diesel
is there anything i need other then whats comes in the kit i need
what sould i buy for asseroies extended brake lines? T-case Drop?
Thomas
Tonight mine pulled a few cars out of snowbanks, and is sitting in my driveway, icicles on the grille, wheels just white cakes of snow, buried up to the lug nuts in powder, straps and chains wrapped around the bumpers, the outline of the wipers clear in 4 inches of snow on the windshield... A tired warrior of the 1980s in a world of low profile tires, front wheel drive, and plastic bumpers, where people stay in their houses until snowplows move the offending substance from their paths, too helpless to travel without AAA and chains and salt, clearing their windows with longhandled brushes while gently stepping around in the snow trying to stay nice and dry.
GmtGmt is offline   Reply With Quote
Old 07-25-2010, 02:49 PM   #2
Davetopay
Re: 6 Inch Lift kit K5 Blazer
Make sure to extend the hoses on the differential breather vents. Make sure it comes with good set of poly bushings for the springs. Also, at that height if you plan on any real off road work, I'd look into beefin up the frame around the steering box and swapping to a crossover steering set up.
Davetopay is offline   Reply With Quote
Old 07-25-2010, 09:33 PM   #3
russgt
russgt's Avatar
A 6 inch or more lift may require making the driveshafts longer
70 stepside
76 blazer
86 Silverado
20 Max Trailering 6.2 Crew
71 Nova SS
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=363634
russgt is offline   Reply With Quote
Old 07-25-2010, 09:52 PM   #4
AJs72K5
AJs72K5's Avatar
6" is right on the border of the stock shafts still working. Any taller will require new shafts.
- AJ
Gray Matter Build - 1972 K5 with some stuff
AJs72K5 is offline   Reply With Quote
Old 07-26-2010, 07:43 PM   #5
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
My old '81 with 6" lift needed to get the drive shafts extended! I have heard that ruffcountry rides like its names states but I have never had one of there lifts in my truck. I wouldn't worry about crossover steering unless you really want it mine wasn't to bad.
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
