84 k10 long tube headers
im deployed and have been buying goodies for my truck, i bought some long tube header for it and am looking at getting some mufflers, but i dont know if i need to get center inlet/center outlet or side inlet/center outlet ect....i cant get my ol lady to jump under my truck and take a picture for me so i have some idea of what to order. ive got a 350 and im going to be running three inch all the way back, just want to make sure i get the right mufflers before i get home. any idea?
also im going to be replacing the 350 thats in it now for a crate or rebuilt 350, does anyone know about the 290 horse gm crate engines on summit/jegs? they only run about 2100....ive seen engines on ebay before i left for deployment for about 2500 or so give or take a couple hundred that claim to get alot more hp and torque. just lookin for opionion...it is my daily drive so want it to be somewhat decent on power and effectiant, some people say to go with a 5.3 or 6.0 but im in the militarty and dont have alot of money to play with and dont feel like dealing with computers. |
Re: 84 k10 long tube headers
First off, allow me to thank you for your service. Where are you stationed? Now for the truck...I assume you are not using an existing exhaust? If not, DO NOT run 3". Unless you plan on running a high RPM big block, you will kill alot of low RPM torque. I would run 2.25" true duals. An X, or H, pipe will help a little, but will affect sound. The mufflers really don't matter, unless you buy a kit exhaust (Dynomax, etc.). Offset inlets will move them away from the side saddle tanks, but center inlets will work, too. Most "turbo" style mufflers are reverse flow, so I would get offset/center and install whichever way works best. As for the engine, it will be cheaper to rebuild than to go crate, especially if you plan on modifying. The 290 horse is a good one, but a cam swap will really help it out. So will heads, but now you are negating the point of buying a crate, since you are paying for a bunch of stuff that won't be used. There are some good build sheets out there on the web, with dyno numbers. Here is a good one: http://www.corvettefaq.com/c3/goodwr...20part%201.htm
Good luck! |
hey thanks man, im currently stationed on New River Air Station in NC, im was wanting my truck to be somewhat loud and crisp sounding, but i dont want it to sound like i got glass packs if that makes sense...i already bought the headers, i know i can go down from there, but if i go with a 2.5 inch i planned on just having duals all the way back...does it help with power to have a h pipe or x pipe in there? my buddy had 3 inch on one of his trucks and it sounded good...and ran good...i couldnt tell you if it would have ran better with 2.5 inch or not cause he replaced the stock exaust...which with the 3 inch i did help with power as to the stock exaust. im also trying to keep myself on a budget...plus i plan on putting a bit more power in it as to what is has right now...here in a few months after i get back. thanks man..i take all advice into consideration and im not questioning you lol just trying to get the most for as little as i can
2.50 inch will be fine.. it will give you headroom as you do mods, which I am assuming a good hot rodder will do... An H pipe or X pipe balances out the pulses from each bank of the engine... an x pipe will give it a more higher pitched F1 sound... the H pipe will sound mellower but still IMO sounds better than duals...
Again Thank you so much for your Service!!!! |
hey no problem...been doing it about nine years or so now
so if i run 3 inch with a H pipe...will i still lose tq power?
i also forgot to mention that right now it has dual exaust and it has 2 inch all the way back and it is starving for air...that why im really thinking 3 inch
Still plays with trucks
With a mild mannered street truck you will. To support dual 3" exhaust you really need a bigger engine than the 350 you are running and a whole lot of cam & compression with great flowing heads. Much more than a typical hopped up street driven truck has.
2-1/2" will flow well enough for quite a bit of power production but not lose too much on a mild mannered truck. It will make it quite a bit louder than it is now too. I ran 11.20's with full 2-1/2" exhaust on my 70 Chevelle that weighed 3900 pounds. That takes quite a bit of HP to do.
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been https://67-72chevytrucks.com/vboard/...d.php?t=484426 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E |
alright so im going to go with a 2.5 inch exaust...no cats and mufflers....flowtech after burners or thrush welded that is the question now.
Chevys Kick A$$
Sweet ya I was going to say my vote would be for 2.5" all the way back, so you can add some more mods in the future since your planning on it and not need to go bigger later! Flowtechs aren't to bad I have never actually ran them on anything though. Did you look into flowmasters at all or too much money for budget? Oh and thank you sir for your dedicated service to our country as well
*HOODS is what I answer too* -'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold ![]() -'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit ![]() ![]() -'86 K5 Blazer Silverado 6.2 4" lift 35"s -'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's -'83 Monte Carlo T-Tops. 126,500 Original Miles -LATER ![]() I would rather push a Chevy then drive a ford!!
![]() Last edited by Hoods69BadBowTie; 07-28-2010 at 04:59 PM. |
The best flowing muffs are the Magnaflows or the Borla Ultraflo...
I have Flowmasters, but they do rob some power... but do sound great |
Chevys Kick A$$
Yea I know lol hes been talking about wanting that deep rumble and 3" exhaust that's why I asked him about the flow masters though.
thanks for the replys gents, its not that flowmasters are outta my budget, i think flowmasters are a bit overrated...their not that bad i think your paying more for a name than anything...i really think im gonna go with the flowtechs, they got a good price and some good reviews, i havent read anything bad on them yet...and they seem really good for the money.
Tags |
headers exaust 350 |
