Old 06-20-2010, 06:12 PM   #251
djmachinist
djmachinist's Avatar
Question Re: 1969 GMC Short Fleet Build
Originally Posted by travlinman View Post
nice build. how far up on the fire wall did u go? and what did you do around the fuse panel steering column and heater box? ive been meaning to do mine but not sure how far i want to go up go around everything or under everything.
thanks
I went everywhere I could get to, I used about 2 " wide strips of hushmat in and around the fuse box. I put down 2 layers in the cab floor and firewall. I finished putting it all back together this morning with the carpets and seat installed. I went for a test drive, nice and quiet, no rattles. The stuff really works! The only problem now is I can now here how much wind noise the vent window and mirrors are causing.
Dale
1969 GMC SWB FLEETSIDE
ZZ 383 CRATE MOTOR,700R4,& 3.73 POSI & VINTAGE AIR
DALE JONES
MY BUILD THREAD: "69 GMC SHORT FLEET"
http://67-72chevytrucks.com/vboard/s...d.php?t=388447
djmachinist is offline   Reply With Quote
Old 07-26-2010, 10:25 PM   #252
gcburdic
Restoration Virgin!
gcburdic's Avatar
Dale,
This is a fabulous build....read through the whole thing....awesome job!!....
I'm seriously thinking about buying those 6 lug Summit wheels too....did you use the spacer as you referenced earlier??...If so, which one did you use and where did you find it??
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 07-27-2010, 07:22 AM   #253
djmachinist
Originally Posted by gcburdic View Post
Dale,
Geoff,
Thanks, I have had good time with the build, I'm not done yet,still have many issues to finish.
The rear wheel spacers were bought from Summit.They listed as a metric version for the six lug pattern. 139.7mm x 30 mm. I think they were made for a Toyota. I took a chance and ordered them, They worked just fine, bolted right up. I did have to install longer lugs in my axles to get full thread engagement. I found the longer lugs at my local Oreilly's parts store. If you
lower your truck more than 3", you might consider the 25mm thk. spacer to
give you a smigen more tire clearence.
Good luck,
Dale
DALE JONES
Old 07-27-2010, 07:27 AM   #254
my67chevytruck
Under Construction
my67chevytruck's Avatar
Great progress Dale, truck is coming along nicely! What year model is your serpentine setup and do you recall what upper and lower radiator hoses you used?
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 07-27-2010, 07:44 AM   #255
djmachinist
Heath,
The serpentine belt and pulley system came with the ZZ4 crate engine. What actual vintage it is I don't know, however the Serpentine kit is listed on the GM web site. I would guess early 90's components. The upper hose is stock for the V8 trucks, The bottom hose is made from two different hoses with metal tube connector. Have no idea of the hose number, they were picked off the parts shelf. Sorry I could not help more.
Dale
DALE JONES
Old 07-27-2010, 07:51 AM   #256
my67chevytruck
Under Construction
Dale, thanks for the info, I have that GMPP serp setup on the '56, and a '94 serp on my sons '67. I bought the hoses already, but was curious as i have seen ppl run diff hoses. It never hurts to have too many part #'s
we used a autozone XL-1171 for the upper, and a Gates part # 20842 for the lower....
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 07-27-2010, 10:36 PM   #257
gcburdic
Restoration Virgin!
gcburdic's Avatar
Thanks for the info Dale.....now gt on wit finishing up this thing...but is it ever done
Geoff with a G
Old 08-14-2010, 11:48 AM   #258
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Selling the seat, so what's next for the interior??
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 08-14-2010, 02:04 PM   #259
djmachinist
Hi Nate,
Yeah, I got a set of Bucket seats and center console from a seat supplier.
I have not installed the seat yet. I've been doing other things like getting rid of the cab mounted gas tank and installing a CPP rear mount under the bed aluminum tank set up. I also lowered the rear end one inch using the CPP lowering block kit.
I now need to paint the back of the cab where the tank came out, Its real nasty looking behind where the tank was. I'll post some pics when I get a chance.
Soooo...What have you been up to on your fine ride?! Any new additions?
Dale
DALE JONES
Old 08-14-2010, 10:55 PM   #260
72BlckButy
Tot Roddin'
72BlckButy's Avatar
No new additions for me lately, and it won't be until winter before any additional projects are even started.
Can't wait to see the bucket seats installed, as well as the other updated additions to your sweet little truck.
-Nate
Old 09-03-2010, 01:54 PM   #261
djmachinist
I thought I would post some pics of my new dophin guage panel. I finally got it installed last week.
DALE JONES
Old 09-03-2010, 01:58 PM   #262
djmachinist
I also added a CPP 19 Gal. Aluminum tank kit mounted under the bed. I then cleaned up the back of the cab, painted it and then added some accoustical insulation by hushmat. I now have room behind the seat to install some stereo
equipment.
Dale
DALE JONES
Old 09-03-2010, 02:06 PM   #263
djmachinist
I had a problem with my seat adjuster rod assembly was broken and tranverse rod was bent pretty badly. So.....I made at trip down to local Ace hardware store and found some 1/16 in. stranded cable. 4 ea. 1/16 in. cable clamps, and a neat aluminum block turnbuckle, and a S-hook. I assembled them into a new seat track adjuster cable. Works like a champ!! I added the S
hook in the middle of the seat to elevate the cable out of the way a bit. The turnbuckle made it easy to adjust the right tension on the cable pull. All for $7.50 .
DALE JONES
Old 09-03-2010, 02:22 PM   #264
djmachinist
I had my original seat for sale, I'm glad I kept it because this is a custom seat from "Discount Truck Seats" that looks great, however it won't fit my 69GMC. It will bolt into the truck with the supplied vertical mounts designed for our series of trucks, however the seat back dimension is about 4 inches deeper than my bench seat back. It shoves me way to close to the dash, pedals, and steering wheel. What a shame because it does look great and has
a really neat fold down buddy seat with a Burl wood armrest, storage area and built in cup holders. Well....I can't use it. My $1000.00 mistake!!!!
Dale
DALE JONES
Old 09-03-2010, 02:26 PM   #265
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Bummer to hear about the seat, but the rest of the upgrades look "really" good!
Nice work Dale!
-Nate
Old 09-03-2010, 03:51 PM   #266
lolife99
67-72 parts collector,…
lolife99's Avatar
I think I like your stock seat better anyway.
Keith
Convert to disc brakes.
Old 09-03-2010, 05:29 PM   #267
djmachinist
Keith and Nate,
Thanks guys, Maybe I can get a couple of bucks from a country sudsucker that likes to set in his front yard while sucking down a few Bruskies in the evening. He could do it in style with this seat!!
And I do like the original seat, I think I will learn to live with it just fine. Now onward to the next task which is to install a stereo system in the truck.
Dale
DALE JONES
Old 09-04-2010, 12:16 AM   #268
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Just read the whole build thread very nice...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 09-04-2010, 12:57 AM   #269
djmachinist
Thanks, I just read thru your project, you have done some really nice work.
Dale
DALE JONES
Old 10-06-2010, 08:19 PM   #270
djmachinist
I decided the Turbo 350 tranny I originally installed was not going to cut it. I purchased a 700R4 OD tranny from Phoenix Performance transmissions in Weatherford, tx. near Ft. Worth. Phoenix offers a special built 700R4 and Torque converter for the GM ZZ4 350 small block which I have in my truck. I also bought the TV cable assembly from them. They direct shipped the 700R4
to Bumbera's Performance here in Houston. Bumbera got the tranny installed yesterday and after a few ajustments to the TV cable she works fine. Nice crisp shifts but not to violent. The acceleration from a dead stop is much better than the Turbo 350. The 700R4 has a much lower 1st gear. She's turning 2000 RPM at 70 mph in overdrive with the 3.08 rear end I have in the truck now. I think I may put in a 3.42 or 3.73 ring & pinion in in the near future. I must say the overall driveabilty of the truck has improved. Thats the old Turbo 350 in the first pic.
Dale
DALE JONES
Old 10-06-2010, 08:25 PM   #271
djmachinist
Its been awhile since I have posted Pics of the truck. I have added quite a few new items like the Pioneer Stereo System. 10 " woofer/amp and two 6 x 9 speakers behind the seat. Two 6 1/2" speakers in the Kickpanels. I found a bench seat console that matches the seat very nicely, It is held in place by a strap.
Dale
DALE JONES
Old 10-06-2010, 08:26 PM   #272
djmachinist
More Pics.....
DALE JONES
Old 10-06-2010, 08:28 PM   #273
djmachinist
again, more pics....
DALE JONES
Old 10-06-2010, 09:15 PM   #274
VA72C10
VA72C10
VA72C10's Avatar
Looks good! I'm sure the 700's a nice improvement!
Old 10-07-2010, 10:08 AM   #275
gcburdic
Restoration Virgin!
gcburdic's Avatar
That looks really nice Dale....what's you gonna put in the unused lighter hole?!?!
Geoff with a G
