Old 07-27-2010, 11:01 AM   #1
muthstryker
muthstryker's Avatar
Clunk coming from rear?
Hey guys, took my truck out of the garage yesterday for a ride around the block real quick and when I brake, there is a loud clunk in the rear. I can feel it too. I cant figure it out... The truck will be alinged this friday and dont plan on driving it untill it is aligned but what could this be?
Is it possible my pinion angle is off causing the drive shaft to clunk? Or?...
The correct drop shocks for the rear are on the way do you think its maybe a shock thing and I should see what happens when I replace the stock shocks with the lowered shocks?
muthstryker is offline   Reply With Quote
Old 07-27-2010, 11:39 AM   #2
willett
Another Day, Another Dollar
willett's Avatar
Re: Clunk coming from rear?
sounds like u - joints to me..
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box
"its hip to be square"
willett is offline   Reply With Quote
Old 07-27-2010, 12:33 PM   #3
muthstryker
See thats what I was thinking, I just replaced them but I know new parts can be faulty, I will have to check those out again. I wonder if the pinion angle can mess up U-joints..
Old 07-27-2010, 02:23 PM   #4
Chlsnk
Chlsnk's Avatar
Definately sounds like a U joint.
***My 84 short bed build up*****
http://67-72chevytrucks.com/vboard/s...68#post3481968
Chlsnk is offline   Reply With Quote
Old 07-27-2010, 02:29 PM   #5
tantrumpipeline
Master Procrastinator
tantrumpipeline's Avatar
i rebuilt my rear end and didn't set the backlash correctly and has this happen, could be worth looking into.
My Buildhttp://67-72chevytrucks.com/vboard/s...d.php?t=395506
20 Duramax tow pig
68 2wd short stepper project
77 2wd short fleet beater
52 short project
tantrumpipeline is offline   Reply With Quote
Old 07-27-2010, 03:04 PM   #6
muthstryker
NVM! I now know what backlash is...
Is this something an alignment shop can do? Kind of new to all of this setting stuff to the proper adjustments anyways..
Old 07-27-2010, 03:05 PM   #7
muthstryker
I will check out my U-joints when I get home if they seem bad or something i will swap them out this weekend.
Old 07-27-2010, 03:09 PM   #8
Ghastlyone
Ghastlyone's Avatar
Another thing you might check, is that your drive line needs to be regreased at the yoke and transmission tail shaft.
I was getting a clunk on my Tahoe Limited and come to find out, this is what the problem was. Popped the driveline out, greased the crap out of it and it was fine after that.
Ghastlyone is offline   Reply With Quote
