Old 07-28-2010, 01:30 AM   #1
Boyd
Resident Lurker
Boyd's Avatar
Edelbrock Fuel Pump Clearance Problem (pic)
I swapped an I6 for a 350 recently. The new engine came with an Edelbrock fuel pump installed. I had to remove the fuel line fitting from the pump when I dropped the engine in because it was hitting the engine tower. Well, I re-installed the fitting tonight, but it's so tight between the tower and fitting that I can't get the hose installed. I could use a 90 fitting, but I'm almost positive the pump is too close to the tower to screw it on. Has anyone else had this or a similar problem before?
The Rotten Mule: '72 Chevy Short Step Project- http://67-72chevytrucks.com/vboard/s...d.php?t=417252
"Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats."- H.L. Mencken
Boyd is offline   Reply With Quote
Old 07-28-2010, 01:36 AM   #2
mstrav1973
mstrav1973's Avatar
Re: Edelbrock Fuel Pump Clearance Problem (pic)
have you tried rotating the housing? I had to on mine to get the discharge where I wanted it. Those pumps can be rotated 360.
Matt
72 chevy k-10, swb, auto, 35's, rally's, posi, 4" lift, 2.5" old style 40 series flows with headers and crossover pipe and some other stuff!!
mstrav1973 is offline   Reply With Quote
Old 07-28-2010, 02:05 AM   #3
ERASER5
ERASER5's Avatar
X2
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 07-28-2010, 02:13 AM   #4
petey-pablo
"THE GREEN GOBLIN"
petey-pablo's Avatar
What Motor mount towers are you useing I6 or 350, That could cause a problem too?
Petey-pablo
"THE GREEN GOBLIN"
1972 Cheyenne 10 Short Fleet Side
Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs.
454BBC TH400,Posi
1971 Cheyenne 10 Long Fleet Side
454BBC TH350,Posi Sold
Drive it like you stole it!
Petey-pablo@sbcglobal.net
petey-pablo is offline   Reply With Quote
Old 07-28-2010, 10:36 AM   #5
Boyd
Resident Lurker
Boyd's Avatar
Matt
Thanks! I noticed the fasteners all around the perimeter and wondered if that would allow it to be rotated, but wasn't sure. I'll disassemble/reassemble tonight after work. Thanks again.
