Old 07-29-2010, 09:17 PM   #1
tys toy
tys toy's Avatar
What is this crossmember..??
This crossmember is located right below the firewall. I cant see it being a trans x member? I believe the th400 are located further back near the tailshaft. We are going to run a 350 &th400. Does it have to come out? Thanks guys!
tys toy is offline   Reply With Quote
Old 07-29-2010, 09:30 PM   #2
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: What is this crossmember..??
Bellhousing mount for a standard trans. It would be in the way for a TH trans
Old 07-29-2010, 09:35 PM   #3
ed2552
ed2552's Avatar
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs
72' GMC C2500, 350, TH400(?), Dana 60
'67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST!
'65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT!
09 Yukon Denali 82k Miles 6.2L/6A
ed2552 is offline   Reply With Quote
Old 07-29-2010, 09:43 PM   #4
tys toy
tys toy's Avatar
Thanks for the quick responses guys. This crossmember is on its way out. Should the frame have factory holes farther back for the th crossmember?
Old 07-29-2010, 09:48 PM   #5
hayhauler71
hayhauler71's Avatar
Yes
Fuzzy
hayhauler71 is offline   Reply With Quote
Old 07-29-2010, 09:49 PM   #6
garyed08
yes it does have factory holes for the TH crossmember.
garyed08 is offline   Reply With Quote
Old 07-29-2010, 10:01 PM   #7
tys toy
tys toy's Avatar
ok, another one for you guys. I have these two crossmembers. The black one has a wider mouth to it and doesnt have holes drilled in the sides like the other. Are they both th crossmembers. They came with the truck,so Im not sure. Thanks again!!
Old 07-29-2010, 11:11 PM   #8
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
I think the wider one could maybe a C20 and not a C10. But I'm not for sure on that.
Ryan
1969 Chevy milk truck
Old 07-29-2010, 11:25 PM   #9
tys toy
tys toy's Avatar
dieselwrencher, do you have any pics of your cummins conversion. I really want to do another truck with a 12v.
Old 07-29-2010, 11:36 PM   #10
Dieselwrencher
Here is the thread of my Longhorn, which isn't done yet. The diesel conversion starts on Pg.3.
http://www.67-72chevytrucks.com/vboa...light=longhorn
Ryan
Old 07-29-2010, 11:46 PM   #11
tys toy
tys toy's Avatar
link didnt show.....
Old 07-29-2010, 11:56 PM   #12
Dieselwrencher
It should now.
Ryan
Old 07-30-2010, 09:09 AM   #13
tys toy
tys toy's Avatar
will these work for the th400?
Old 07-30-2010, 09:29 AM   #14
bigsnookmaster
bigsnookmaster's Avatar
I know the black one will, and I think you can leave the other one in if you cut the side ears off the tranny, but it will be easier if you take it out.
bigsnookmaster is offline   Reply With Quote
Old 07-30-2010, 09:55 AM   #15
tys toy
tys toy's Avatar
Thanks bigsnookmaster. Hey I see you are from st.pete. Was fishing there a few years ago on the old sunshine hwy bridge.
