71 vs. 69 question
I am brand new to this site and have really been impressed with what I have seen so far, there is some great info on here so I am hoping someone can answer a question for me.
I just purchased a 71 Cheyenne long bed that had been sitting for the last five years. Overall the truck is in great shape and I couldn't pass up the great deal. I had planned on cutting it down into a shortbed; however I just also came into the possession of a 69 shortbed without a bed. The 71 is still a very driveable truck but I want to do a frame off rebuild. I am going to completely rebuild the 69 frame before I start on the body. My question is could I also use the 69 cab in place of the 71 so I can keep driving the 71 as long as possible or are the cabs that much different. From comparing the two I can't see anything that jumps out at me but I know there are people on here having to modify their 69-70's to fit a 71-72 gas pedal. I know this is a long post but any and all help would be greatly appreciated. The cabs are very similar in shape as in both have very little rust on them.-Jamie |
Who's got steelies?
![]() Join Date: Feb 2006
Re: 71 vs. 69 question
There is really not much difference. If its going to be a temp transplant, just use the 69 pedal & rod assembly to control the carb.
![]() ![]() ![]() ![]() ![]() ![]() How to add a trip odometer to your 67-72 stock speedometer How to rebuild your Q-Jet My Truck Page My Youtube Channel |
It would be permanent, not temporary as I would do all the bodywork to the 69 instead of the 71.
Moderator
![]() Join Date: May 2007
About the only difference in cabs are a high hump or low hump transmission cover....oh and the 72's had the rear view mirror mounted to the windshield, not the roof of the cab. Other than that, I believe they are all the same. Welcome to the board and good luck!
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
is very serious
do not cut a long bed to a short bed i will cry
1967 C-10 2wd fleetside LB 350 4spd (dads) - sold 1970 C-10 2wd fleetside LB 307 700r4 - sold ![]() 1969 C-10 2wd fleetside LB 327 3spd - sold ![]() 1969 C-10 2wd fleetside LB 350 th350 - sold ![]() 1967 C-10 2wd fleetside LB 250 th400 -project in progress Chevrolet=one who is dignified enough to expect every occasion is a special one and sees it fit to wear a bow tie... may others come under dressed. |
SWB 4x4 Collector
![]() Join Date: Jun 2001
For a purist, the 71 cab has subtle details different than that of a 69'. It depends what you want to do for a restoration. The 71' rear view mirror mounts on a raised pad, and to my knowledge is the only year that this raised area on the cab exists. The 71' will also have a vent by the vin plate in the door jam and not on the 69'. The 71' being a Cheyenne means it has the headliner holes punched in the roof, and the 69' (unless a CST) will not. Like I said, if you don't plan to still make it a 71' Cheyenne, I wouldn't worry about it and use the 69' cab. With using the 69' frame, it wouldn't matter anyways for a stock restoration under the 71'. Good luck with what you decide, sounds like a fun project. Trevor
TREVOR ![]() ![]() ![]() ![]() ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=624819 ![]() ![]() :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
dont worry about cutting the bed people do it all the time.
i would look at both truck and figure out a plan. if u wanna keep both trucks or redo 1 and have another for parts ? id keep driving the 71 while redoing the 69 until i got to a point where i needed or wanted the 71 parts and start swapping things over. u can sell what u wont need/use and get some money for more parts. good luck
94 ls swap silverado 65 Pontiac 78 c30 crew cab dually (parted and gone) 82 c30 crew cab dually ( now building ) 91 r30 crew cab dually (parted and gone) 69 swb-sold 71 lab sold all in progress......__ ..........._______ |__\__ ..........|__(O)______(O)] ........................ |
Back in the sticks
The other plus to the 71 is disks up front. Heck with it, just redo one at a time and drive the other!
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer w/Tuned Port 2010 2SS/RS Flaming Orange Camaro 2011 K1500 Suburban 2014 K1500 Pickup 2008 Nissan Altima? The wifes' hoopty |
