Old 07-31-2010, 04:27 PM   #1
1972CST
1972CST's Avatar
Spindle bearing and seal kit???
I am in need of replacement spindle bearings and seals for my dana 44 axle. Where is the best place to get them and are they all the same ... ford, jeep, chevy? I have found a few kits online but cant seem to find them locally at napa or anyplace like that. Thanks for the help... once again!
1972CST is offline   Reply With Quote
Old 08-02-2010, 08:07 PM   #2
OLDCHEV4X4
OLDCHEV4X4's Avatar
Re: Spindle bearing and seal kit???
The only part number i have memorized is SBK-1 and that is for the stub shaft bearing, stub shaft seal, slinger and inner seal. You will need this plus the wheel bearings and wheel bearing seal. This is for a chevy, not sure if it fits other brand D44's. NAPA will have everything.
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 08-03-2010, 09:03 PM   #3
1972CST
1972CST's Avatar
Thanks alot i got the kit. Does the small seal fit down in the spindle to seal the other side of the needle bearing?
Old 08-04-2010, 06:03 AM   #4
LONGHAIR
The seal goes in after the needle bearings, with the lip pointed inward, to keep water/mud away from the bearings. Be sure to grease them, also wipe a little bit of grease on the lip of the bigger seal so lube it against the back of the spindle.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 08-04-2010, 11:16 AM   #5
Burt4x4
Burt4x4's Avatar
I just happen to have that part number:
Spicer Spindal Repair kit 706527X for D44.
If memory serves it come with seal, bearing and thrust washer
Edit ...nevermind...I didn't read the other replys first...
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 08-04-2010, 04:56 PM   #6
1972CST
1972CST's Avatar
So the big "dust" seal and the small lip seal both seal against the back side of the spindle? I wasnt sure if the small lip seal went inside the spindle first and then the needle bearing after the small seal? \
I appreciate all the help... I bought this axle partially disassembled and now im trying to get it back together. I have had a hard time finding reference material or a manual for this part of the axle.
