how to tell what year a gmc is
well im gonna look at a gmc tommorow and from my normal chevy observations it is a 69 72 cause the hood but how can i tell the years apart you know 69 70 or 71 72
![]() Join Date: Nov 2003
Re: how to tell what year a gmc is
69-70 is tough, the grille will be the plain solid grille. No paint, and no GMC letters.
71-72 will have the grille with the black paint in the middle. 72 will have the 72 only doors, mirror on the glass, and a few other slight differences. Of course the VIN will tell you the year too.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
I don't know about the 69, but the 70 GMC with polished aluminum grill has a black stripe around the grill, but not down the nose.
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
Check out thjis website. It should answer all your questions?
http://www.pattson.com/maych/67_72_gmc.htm Hope this helps?
![]() ![]() ![]() LIFE AIN'T EASY WHEN YER FAT AND GREASY! GMC= Got More Class! ![]() ![]() |
as a kid it use to be cool to find the 2 digit year on the tailight lens, every year was probably a new style so the lens did not carry over and it was easy to tell what year it was.
I am not sure about 69-72 if they had the same lens carry over or not. ... I am not much help just remembering being a kid.
eat,work,spend,sleep,repeat. |
![]() Join Date: Mar 2000
The top bar on some 69 grilles may have little extensions that run under the eye brow trim. I had one 69 like that.
Saskatoon, Saskatchewan Canada Last edited by StingRay; 07-31-2010 at 09:51 AM. |
just check the vin to know for sure. the 3rd number will be the last digit of the model year. example ce148f####### the 8 means 68.
#8 | |
I used to be able to do that to all brands of cars, till the 90's when everything just became an unstyled blob LOL! I think that's alot of the reason I like the older stuff, I know what I'm looking at!
Rob 72 C/10 (under reconstruction)(destruction ? LOL) 48 Willys CJ2A 1952 Super "A" Farmall (Grandfather's) |
Ohio Dan,
Good link, thanks for posting it! Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
