HELP I need a measurment!!!!!!!!!!!!
I need a measurment from the bottom of the radiator support to the frame bracket it attatches to. Basically the thickness of the radiator support mounting hardware (washers rubber etc.).
I don't have a radiator support mount kit yet, but i need to shim it on the chassis at the right height thanks!!
My Build thread http://www.67-72chevytrucks.com/vboa...d.php?t=408574 |
1961 crewcab
Re: HELP I need a measurment!!!!!!!!!!!!
my 63 and 65 both look to be 3/8 of an inch.
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
ok thanks thats about what i figured. that will get me close enough today.
yup - I have the mount kit on the work bench in the garage - 3/8" exactly rubber and steel washers together
