TUKE-NoBullChit Customs owner
anyone got any pics of after they cut 1 coil off the front springs without dropped spindles or anything?
i got 1 leaf on the passenger sde n the back that is cracked, so i want to take that particular spring from both sides in the rear,but since the truck sits level front to back now, im afraid the front will end up higher. i need an algnment anyway so i figure why not. ill go lower once i find spindles on a week i can afford. any pics tho guys?
OWNER @ NBC Customs...No Bull Chit....'92 GMC C2500 ECSB 350/TH400, '57 FORD SKYLINER (My dad's for now, but its really mine-you'll NEVER see a cooler car at 7 years old lol), '42 ford rat rod shop truck (new project), 91 CHRYSLER VOYER MINIVAN (shop van for now) http://www.facebook.com/#!/nbc.customs
Happy to be here
![]() Join Date: Mar 2000
Re: cutting 1 coil up front
I can't offer pics with a cut coil and no dropped spindle, but it sounds like you have a good plan.
gets board easy.......
i have found that cutting 1 coil will lower approx 1.5 inch.
I cut 2 coils and it dropped about 2.5 inch if that helps |
#4 | |
All About the BOWTIE
CaliDude76 "... Being "SQUARE".. is where it's at...." ![]() Proverbs 15:30 .... "A Cheerful look brings joy to the heart, and good news gives health to the bones..." Be exceedingly blessed today, my friends!... |
thanks guys, helps alot. only problem now is i have to find the cracked one again. should have marked it when had t on the lift. i jacked it up today and swapped to some rallies with the rare early centercaps that look way better on my truck. i looked, i know it was on the passenger side, but couldnt find the crack. its not the overload one, but i gotta take it out.
if i happen to wan tthe extra 1.5 and im sure ill have to cut the bumpstop mounts off and make something work, no biggie, but will the shocks bottom out?
im probably going to do it tommorrow so im askin now lol. anyone know what car i ask for if i need new shocks? rear i should be fine wih just one leaf removed i assume.
6.0 powered square
1coil cut
![]() ![]() 1 coil cut , drop shackles and a few leafs removed
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 Last edited by flamingbig10; 08-01-2010 at 01:43 AM. |
this is 1 leaf out and 1.25 coil cut on 15x8 with 275/65r15
dont worry about the shocks, i havent had any issues with them bottoming out
cool, im heading to the shop in a lil while to attempt it hopefully. at least the rear
| Bookmarks |
