Grandpa in the rustmobile...
3 spd man. trans mounts, rubber goes where?
Im trying to figure out which way the rubber square goes?
Between trans/crossmember? Between bolt head and crossmember? Its 1 big bolt and a funny looking washer thing.. Am i missing something?
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
Re: 3 spd man. trans mounts, rubber goes where?
Each side should have two rubber mounts ... a U-shaped one and a square one.
The U-shaped ones go between the bellhousing and the crossmember. Open end of the "U" facing down (and cupping around) the crossmember. The square ones go on the underside of the crossmember ... between the crossmember and bolt head. Those funny looking washer things go directly under the bolt heads. After the bolts are tightened, bend the little "ears" down against the flat sides of the bolt head to keep the bolts from loosening. |
thanks! I must've thrown the U ones in the purple power bucket..lol!!
