Old 07-10-2010, 02:04 PM   #501
cheepin
Re: Tbi swap build thread
Originally Posted by rfmaster View Post
You need to verify POST functionality - ignition key from off into run position, but do not attempt to crank engine over. You should see SES light go from solid on blink off back to on. Meanwhile fuel pump must come on for about 2 seconds and shut off. If the pump does not come during this check the likely culprit is a bad fuel pump relay, wiring between ECM (Pin A1 dark green/white) and Fuel pump relay coil circuit, or possibly blown driver transistor that provides + 12V to energize FP coil. The black/white wire in the FP relay socket must be grounded. Otherwise coil will never be energized.
When you pour a little bit of gas into TB engine fires and oil pressure switch NO contacts close once oil pressure is in excess of 6 PSI thus providing power to the fuel pump.
Check and see if there +12 volts supplied by ECM to FP relay coil circuit when engine is running (the aforementioned A1 dark green-wht wire) .
//RF
I have the Fuel pump on a switched relay not the factory one.I do have the factory one under the hood.And hook up to the comp.
1984 1ton 4x4 crew cab dually 6.2 diesel,465,205,D60,D70,1987 3/4ton 4x4 suburban 5.7 FI350,TH400,208,1985 CJ-7 FI406,465,205,D60,FF14, 1970 Jeepster 350,465,205,D44,FF14,
cheepin is offline   Reply With Quote
Old 07-10-2010, 10:50 PM   #502
USSkoval
That should work - but keep in mind that fuel slash during braking or acceleration may uncover fuel sock casing FP to suck in some air.
Yes, fuel slosh is a concern with these tanks. I think if I don't let them get below 1/4 tank it should be OK. I try never to let them get that low anyway.
-Andy
'77 K5 Blazer
'78 K10 Shortbed
'78 C20 Suburban
'79 K30 Crew Cab Dually
'84 C10 Short Stepside
'88 K20 Suburban
USSkoval is offline   Reply With Quote
Old 07-11-2010, 07:04 PM   #503
cheepin
Where does the tan/white wire connected to the oil pressure switch suppose to go?
Old 07-12-2010, 09:21 AM   #504
BGRAFX
This is a great thread dedicated to the tBi system.
BGRAFX is offline   Reply With Quote
Old 07-12-2010, 11:04 AM   #505
rfmaster
rfmaster's Avatar
If you have a three wire oil pressure switch connector then in general (depending on the model year of vehicle that harness was sourced from) pinout is:
Orange - Battery
tan/white (or gray) - Fuel pump
brown - oil pressure light (depends on the oil pressure switch part #)
The first two wires are usually larger gauge wire (for current capacity)
//RF
"The Beast"
1975 Chevrolet C20 longbed
350/700R4! with 3inch body lift
Dual Flowmasters Super 40's!
TBI retrofit completed (2007-07-29)
New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17)
rfmaster is offline   Reply With Quote
Old 07-12-2010, 07:38 PM   #506
cheepin
Orange - Battery
//RF
Cool thanks!Probably not my last question on here though.LOL
Old 08-02-2010, 11:16 AM   #507
rfmaster
rfmaster's Avatar
Gents
This thread has been a bit quiet for a while. Meanwhile I have been working in my garage on 383TBI with a few surprises. As with any other project there were several setbacks...
Well, after almost a year of building I have fired my 383TBI (Fuel injected) on the engine test stand. Several issues stood in my way before it was fired:
1) distributor was 360 out (wrong TDC) (dahhhh!)
2) couple loose wires
3) leaky radiator (found out too late).
4) leaky oil pressure gauge (need a better way to plumb an oil pressure line).
I shot this video on Sunday after resolving all, but radiator issues.
sooooo - what's next?
Radiator
IAC wiring needs to be addressed (simple pin swap)
adjusting fuel pressure on a VAFPR
fuel maps (VE tables)
//Alex
"The Beast"
Old 08-02-2010, 11:09 PM   #508
mcbassin
Still Learning
mcbassin's Avatar
RF,
Awesome work on this new project! Wow you really went all out on this one! Nice stand and control panel too! What is the plan for this power plant? Sorry you found a leaky radiator.
Old 08-03-2010, 11:20 AM   #509
rfmaster
rfmaster's Avatar
Originally Posted by mcbassin View Post
RF,
Hey Mike
Yes, thank you very much - I started about a year ago on this engine build when I pulled vortec 350 from JY. Originally, I was planning to drop rebuilt 350 vortec into my 75 C20, but after checking heads for cracks (actually two sets of 906 vortec heads that I had - four out four were cracked) this project morphed. So, around Thanksgiving last year I went all out for high performance stump pulling 383 build, naturally fuel injected (TBI). Based on the build sheet this powerplant (with a proper tune) should be capable of about 360 to 380HP and 400+ ft-lb of torque. Just on cam specs torque on this engine will be flat from 2000 to 4500 RPM (around 400+ ft-lb). It is an ideal power plant for lighter truck (fun) or serious tow rig. Super 23 Trick Flow 180 can support more HP, but that's not what I was looking for. My office mates (gear heads naturally ) are teasing me right now when I am going to get a classic ride (60's Camaro or Chevele) to drop this into. First - I have to coordinate this acquisition activity with the kitchen queen, which is not going to be easy. But time will take care of that - hopefully.
Engine test stand - since I do not have a MIG/TIG welder I end up building it using 30x 36" 3/4" plywood with diamond plate. 2x 2x8 and 1x 2x6 along with 3x cross bolted (1/2" bolts) uni-strats provide sturdy platform. 4" wheels allow for easy movement in my garage. 4x cut to length uni-strats provide vertical support. The whole idea for this engine stand that at the end of the project it can be fully disassembled into smaller parts for storage. Control panel - used a peace of scrapped 16 gauge of sheet AL - drilled, punched all holes followed by a trip to a brake to shape into final shape. Masking tape makes labeling a breeze.
Meanwhile - immediate tasks.
1) new radiator for engine test stand should be arriving shortly (another $100 I did not want to spend!) Found out that plastic tank - AL core radiators can not be repaired.
2) Have to swap pins on IAC connector - BBC throttle bodies use unique IAC motor and its wiring is slightly different from SBC.
3) Fix leaky oil pressure gauge. It is insane, but why mfg ship oil pressure gauges with crappy fittings and lines is beyond me.
4) Start tuning with EBL
//RF
"The Beast"
Old 08-04-2010, 11:40 AM   #510
kcblazer75
kcblazer75's Avatar
Hey guys,
I know it has been said a hundred times, but this is a great thread. Thanks sooo much to the experts. You guys should get paid for this.
I am doing a conversion on my 75 K5 blazer right now. Every question I have had has been answered earlier except this one.
My donor vehicle is a heavy duty 89 pickup (5.7) with an 8747 ECM. Oh, and YES, it DOES have a knock sensor! Go figure... No prob.
I have an extra wire on my ALDL connector that I cant identify. It is solid brown and on pin C. In the donor, it went up into the under dash harness. Who knows where it went after that. Cant find it on any diagrams.
Any idea?
Thanks again
Keith
kcblazer75 is offline   Reply With Quote
Old 08-04-2010, 11:49 AM   #511
68 TT
Still plays with trucks
68 TT's Avatar
Hey Mike
//RF
Sounds like a great project. What are the cam specs in the 383?
I am just about ready to get the 408 from my Malibu dropped into my 67 K10. Maybe this weekend. Once I get the bugs worked out of the truck I will be converting it to TBI. I think the lumpy cam will be a bear to tune but I am going to give it a try. I really like the way the engine runs and sounds but if I have to swap out the cam for something more computer friendly I will.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 08-04-2010, 02:45 PM   #512
mcbassin
Still Learning
mcbassin's Avatar
Awesome work indeed. Hard to imagine building a stand that nice without the use of a welder.
Hey Mike
//RF
That's interesting I have had several fixed in the past, they just straightened the tabs out and changed the plastic tank. Usually around $50. They almost always crack on the dirver side first. This is a result of short drives where the truck doesn't have time fully get up to temp. and the driver side takes all the heating and cooling cycles. Cracks first every time. Good luck with that.
Old 08-04-2010, 07:55 PM   #513
rfmaster
rfmaster's Avatar
The radiator - fan assembly was scored from junked Acura Legend. These cars are plentiful (JY) here in So Cal and replacement parts for JA cars tend to be dirt cheap (most are Chinese copies or Taiwan for a better quality ). The two rad shops that I've visited basically told me flat out that they do not touch plastic tank/AL core based radiators - new replacements are dirt cheap and there are fewer returns vs. repaired. My rad had a bad core - according to tech at one fine establishment it rotted out from inside out.
//RF
"The Beast"
Old 08-04-2010, 08:03 PM   #514
rfmaster
rfmaster's Avatar
Arrow Re: Tbi swap build thread
TT
Yep, you know it all too well that stock ECM calibration will not handle large overlap, tight LSA bottom of the page camshaft. For my 383 build, since I have OE roller block (880 vortec from '97), I went with Comp Cam 08-304-8
Specs:
Duration at 0.050 210/220
Valve Lift 1.5:1 .500/.510
LSA (deg) 112deg
This cam might be a bit on a smaller side than some other cams, but I am after mild manors and really did not want to spend countless hours tuning it (been there - done that). Even with EBL and WBO wild cams can be a bear to tame.
//RF
"The Beast"
Old 08-04-2010, 08:17 PM   #515
rfmaster
rfmaster's Avatar
Originally Posted by kcblazer75 View Post
Hey guys,
Any idea?
Thanks again
Keith
ALDL Pin C goes to AIR diverter enable solenoid. In you case you can trim and forget it unless required by local regulations. Pin C allows to monitor functionality of the AIR diverter.
As for 8747 ECM - I have only seen one flavor - without KS. It is also possible that some one swapped 8747 into 7747 equipped truck. 8747 ECM will work - it will simply ignores ESC module input. Otherwise, the two ECM's share identical I/O. In the past I found 8747 in HD 3/4 and 1 ton trucks and vans as well as specially modified chassis. In other words - who knows...
//RF
"The Beast"
Old 08-05-2010, 11:28 AM   #516
mcbassin
Still Learning
mcbassin's Avatar
Does anyone know where I can get a copy of the wiring diagram for this TBI setup. I have looked all over through my emails and I can't seem to find the one I had. My donor is 1992 5.7 from a Buick Roadmaster car. Thanks
Old 08-05-2010, 11:31 AM   #517
kcblazer75
kcblazer75's Avatar
//RF
Thanks RF.
I assumed ALDL pin C was something like that, but I wanted to be sure. I dont need it.
The donor WAS a 1ton pickup. And the KS wire was uncut and connected to a KS module in the block. All wiring looked original to the truck. It did have an AC Delco replacement ECM, but the AC Delco PN clearly ties to an 8747. (Dont have the number in front of me.)
Now that I think of it, most of the wiring colors matched the 7747 scheme. In the diagrams I found there were a few color differences, like grey vs tan/wht.
I think you are right. This was a 7747 1 ton truck. The original ECM went bad, so without comparing the numbers someone dropped in what is normally on these trucks, an 8747.
I have a 7747 from a burb hanging around, think I will use that one instead.
Thanks for the help!
Keith
Old 08-05-2010, 11:39 AM   #518
68 TT
68 TT's Avatar
Auto Zones web site has quite a few you can download in the vehicle repair guide section once you enter a vehicle.
Old 08-05-2010, 01:14 PM   #519
mcbassin
Still Learning
mcbassin's Avatar
thanks 68 for the tip,
unfortunately, AZ doesn't have one for this model.
Old 08-05-2010, 01:24 PM   #520
68 TT
68 TT's Avatar
Put in a 92 Caprice with the 5.7 TBI. I just did and they are there on the AZ site.
It will probably be the same ECM and engine wiring as the Buick. Should be close enough to get the job done.
Old 08-05-2010, 01:39 PM   #521
68 TT
68 TT's Avatar
TT
Specs:
LSA (deg) 112deg
//RF
We are not too far off on cam specs and I have a few more cubes so I might be OK. My duration is a little high though.
Performer RPM cam Specs:
Duration at 0.050 234/244
Valve Lift 1.5:1 .488"/.510"
LSA (deg) 112deg
It has just a gentle lope to it in the 408. In my old 327 the same cam idled much rougher and loped a lot. It will pull 10 to 12 inches of vacuum at idle. May not be enough. We will see.
Old 08-05-2010, 02:32 PM   #522
mcbassin
Still Learning
mcbassin's Avatar
Thanks 68, I went back through all my old emails from this account and found the diagrams.
Now I need help making this freaking speedo work! HELP
Old 08-05-2010, 04:24 PM   #523
rfmaster
rfmaster's Avatar
LSA (deg) 112deg
If you have ability to write your own EPROM (or EBL) 10 to 12 in-Hg can be dealt with. The MAP sensor will report low vacuum at idle and low MAP threshold (to avoid DTC 33 set = low manifold vacuum level) needs to be increased.
"The Beast"
Old 08-05-2010, 04:30 PM   #524
rfmaster
rfmaster's Avatar
Exactly - 90-93 B-bodies (Chevy and Buick) used 16136965 ECM. These 5000+ lb land yachts used 5.0 or 5.7L engines (same ECM, different BCC).
//RF
"The Beast"
Old 08-05-2010, 04:43 PM   #525
68 TT
68 TT's Avatar
I can burn my own chips. I will give it a try with the 7427 PCM and see where it goes from there.
I would love to run RBob's EBL but I am using a 4L60E so it would have to be a piggy back system unless he has developed a PCM version of the EBL.
