Old 08-02-2010, 04:00 PM   #1
camshaftgsxr
camshaftgsxr's Avatar
whats the stock height of a c-10
an 84 to be specific, swb, 2 wheel drive, i need to find out what my current drop is and i have no clue where to measure and what the numbers are stock, so if anyone can help i'd greatly appreciate it
camshaftgsxr is offline   Reply With Quote
Old 08-02-2010, 04:06 PM   #2
87 chevy silverado
Re: whats the stock height of a c-10
try this?
http://www.lmctruck.com/icatalog/cc/full.aspx?Page=55
87 chevy silverado is offline   Reply With Quote
Old 08-02-2010, 04:54 PM   #3
camshaftgsxr
thank you, but not quite what i was looking for, my truck has been lowered and i don't know how they did it or how much. i can measure the height of it if someone can provide me with where to measure from. i need to know where it sits as far as how much its lowered
Old 08-02-2010, 08:10 PM   #4
bark
I would like to know this to, whom ever measures a stock truck has to make sure to measure from the bottom fender edge to the center of the spindle or axle, or center cap, cause tire size will effect the height to the ground. I have some beaters at the farm, if I get a chance I will measure them up and find out for ya
bark is offline   Reply With Quote
Old 08-02-2010, 09:03 PM   #5
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
what would be a better way instead of eye balling the "center" would be to hook the tap measure under the lip of the bottom of the rim center, and then run the tape measure upwards, centering the tape measure over the center cap and finally taking a measuring at the bottom of the fender.
same concept as bark, but more accurate..
clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 08-02-2010, 09:33 PM   #6
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
If I remember correctly, ~32" front/34" rear.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 08-02-2010, 09:37 PM   #7
1LowToy
Out of all the ways to measure, I did this measurement in inches with a measuring tape, lol
Front about 18.25 from center cap to fender
Rear about 19.75 from center cap to fender
1980 I6 motor 57 k miles old lady used truck. Rear springs are now 3 leafs plus the overload leaf. No mods yet and some stuff in the back (hood spindles and control arms)
1LowToy is offline   Reply With Quote
Old 08-02-2010, 10:04 PM   #8
gchemist
gchemist's Avatar
Height should measure from the ground to fender lip. Stock tire size.
Old 08-02-2010, 10:16 PM   #9
camshaftgsxr
what is the stock tire size? i can do the math, now when you say the fender lip, where on the lip exactly
Old 08-02-2010, 11:34 PM   #10
gchemist
gchemist's Avatar
Stock = 235/75R15
Lip = center of wheel well directly over the tire/center cap.
Old 08-02-2010, 11:38 PM   #11
bark
ran out to the garage, and found 25 3/4 fender lip to the ground on all four corners, thats on 255/60 15 and 295/50 15
thats 6 1/4 front and 8 1/4 rear lower then stock on stock tires, but forgot to measure wheel centers for actual drop
