Retired Air Force Veteran
![]() Join Date: Aug 2007
Step Side Fender Removal
I am trying to remove the step side fenders. I used PB Blast on the nuts inside the fender wall. They all turn - but only so far. Now the Phillips Head Bolt inside the bed is turning. I tried to keep it from turning with a screw driver while using a socket to turn the bolt - no go. I am having some welding repairs done and it would be much easier to weld if I remove the fenders. If I cut the heads off pull the fenders off that way, is new hardware to reattach the fenders available/where?
Harry 69' SWB Step Side 1/2 Ton w/68' Front Clip Swap from Leafs to Trailing Arms (Complete) Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front) 3/6 Drop ![]() Help Support The Board Click Here For Information On How To Subscribe Krue's FAQ Page Vendors |
Re: Step Side Fender Removal
i find grinding off the head with a cutoff wheel is the best fastest way to remove fenders and do the same with the bolts holding beds down too
hardware store has nuts and bolts
71c-10 350/2004r/4:11 lowered3/4 longbed/dead by hurricane MEANING OF DEATH::::: SOMEBODY ELSE GETS YOUR STUFF DONT BELIEVE EVERYTHING YOU THINK TAKE MY ADVISE;I DON'T USE IT ANYWAY Last edited by cdowns; 08-03-2010 at 10:01 AM. |
Thanks for the info
Kill Bill...et
Ace hardware has EVERYTHING!
Thanks, there's an ACE right here in the neighborhood
Harry 69' SWB Step Side 1/2 Ton w/68' Front Clip Swap from Leafs to Trailing Arms (Complete) Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front) 3/6 Drop ![]() Help Support The Board Click Here For Information On How To Subscribe Krue's FAQ Page Vendors Last edited by myoldchevytruck; 08-03-2010 at 01:07 PM. |
![]() Join Date: Mar 2005
i spot welded my bolt head to the bed side so i could remove the nut.
