![]() Join Date: Jan 2008
63-72 Calif Comm Black Plate sequence
I've been looking for some correct black commercial plates for my
recently purchased 1967 C10. There seems to be very little documentation on the internet regarding the correct issuing sequence for Black Commercial plates in California. Maybe someone here already knows or has a theory. I've been doing my own research and here's mine. There seems to 2 different issuing sequence formats from 1963 to 1972. I don't think that there is an exact date for the change because it would have been different for each individual DMV Office. I think that as their supplies ran out for the first sequence they would begin issuing the second. The first sequence in 1963 began with an (A 12 345) format. The issuing sequence determined by the first letter. I think the DMV miscalculated the number of commercial plates that would be issued because this sequence seems to reach the end of the alphabet somewhere in the 66-68 years depending upon the individual DMV Office. The second sequence began with a (12 345 A) format, with the issuing sequence determined by the last letter. I've seen black commercial plates on 1971 and 1972 trucks that only seem to extend mid-alphabet. I've been keeping a lookout for for the last few months for local pickups with black plates and the theory seems to play out. I just purchased a set of (Y 70 584) plates that I think would be correct for my 1967 C10. There is a local nicely restored '67 Longbed with Black plates that start with a V and he believes they are original to the truck. If you have a California truck with black commercial plates that you know are original to your truck...please let me know the year and plate number to see if we can verify the theory. Thanks!!
Wayne Sunny Rust-free Southern California |
Moderator
![]() Join Date: May 2007
Re: 63-72 Calif Comm Black Plate sequence
Boardmember "Stocker" has a set of Black commercial plates on his 72 K20. Might want to PM him. My 72 has blue plates, ending in K. Good luck.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
Junior Member
![]() Join Date: Sep 2005
On my 71 I have 12 345L, but in blue......................Flat67
I'm not sure about the Blue plates. California starting issuing Blue plates for 1970 passenger and commercial vehicles.
My understanding is that some DMV offices had a surplus of Black commercial plates and they issued them to some lucky 1971 and 1972 trucks and vans.
Moderator
Most 1972 trucks had blue plates. Most 1971 trucks had black plates. Stocker is in fact the only 72 I have seen with black plates.
Mine were blue originally....I restored them and made them black
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul Last edited by leddzepp; 08-02-2010 at 09:36 PM. |
Active Member
On my 68 it is 90xxxA, our 69 was 49xxxC, my old boss's 69ish ferd was another 49-C,
all original to Central Cali Coast. My neighbor's 68 is 85xxxC not sure of original location of issue. Max
Never try to teach a pig to sing; it wastes your time and annoys the pig! ![]() Gets More ChicksMy lugnuts require more torque than your honda makes! 68 GMC, 4X4 conversion w/73 k20 running gear and springs, 350 4spd, 4.10's, D44 powerlok front, 14BFF govlock rear, 33" tires, lifted 4". |
20' Daredevil (Ret)
![]() Join Date: May 2003
Here I am... leddzepp has an excellent memory -- or did a bit of searching -- or both.
The black plates on my early '72 (built Aug. 1971) have a sequence of 12 345 A. In fairness, I bought the truck in 1977, but there has been no indication of a repaint from blue. I have scraped, scratched, neglected, and generally abused them and not a speck of blue to be found. There was nothing customized or fancy about the truck -- it's a K20 with twin saddle tanks and 4:10 gears, and had split rims with 8-ply 7.50-16s when I got it. The PO had installed (and removed) an equalizer hitch. Hardly the type of truck someone would strip the paint from the plates and respray from bare metal, imo.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
My '67 has the original plates, and it's V 26--- (can't remember).
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD ![]() Click here to support the board Philippians 4: 6-7 |
TILT COLUMN GURU
![]() Join Date: Dec 2006
Ask C/10King He knows the correct sequence.
![]() He'll even bust out the "Photo Album"
kevs_classics64 64 Impala SS Conv 72 Blazer 2wd 75 Jimmy 2wd 63 Belair wagon 02 Silverado ext cab. DD RIP EL JAY Last edited by KevsClassics; 08-03-2010 at 02:04 AM. |
I believe your theory is real close to being correct, I've been doing my own homework on the sequence for a while, I believe depending on what part of California you're from, the change from letter first/letter last Commercial black plates occurred in both 1967 and 68, I presently have a 67 gmc that came from the original family (with all the paper work) and the plate starts with a Q. My cousin has a 68 that starts with a Q also, I've had a couple of 67 that have ended in A, and one that started with a V. In closing I will submit some photos.
C/10 Rene 1966 Short Fleet "The Hag" 1967 CST Short Fleet "Dark Poly" 1971 Short Fleet 1970 Jimmy Custom 2 WD "Golden Ticket" 1972 Blazer 2 WD "Retro Blaze" |
Lucky Teter at the wheel
I've got a 12 864H black plate on my 1970 C20 from the LA area, built in Fresno. Stayed there in the same place its whole life til I bought it last year and DROVE it back to Memphis. Only had 1 bit of trouble, a flat.
Drew YOUNG FRANKENSTEIN (Finished with MAJOR Surgery - IT'S ALIVE!!!) The Bride is currently under the knife!
#12 | |
TILT COLUMN GURU
I Don,t buy that theory. Because when you buy a brand new veh. The plates are sent from main DMV in Sacto. Not your local Dmv office. JMO
kevs_classics64 64 Impala SS Conv 72 Blazer 2wd 75 Jimmy 2wd 63 Belair wagon 02 Silverado ext cab. DD RIP EL JAY |
#14 | |
#15 |
Okay, let me rephrase that a little bit better. Sacramento designates which counties gets which sequence, And the plates are issued, until that sequence has exhausted.
C/10 Rene 1966 Short Fleet "The Hag" 1967 CST Short Fleet "Dark Poly" 1971 Short Fleet 1970 Jimmy Custom 2 WD "Golden Ticket" 1972 Blazer 2 WD "Retro Blaze" Last edited by C/10 King; 08-03-2010 at 01:01 PM. |
#16 | |
TILT COLUMN GURU
#17 |
Remember, It's only a theory.
#18 |
![]() Join Date: Feb 2001
And so the mystery continues
...stay tuned for more but until that time lay back and listen to our favorite song: See the USA in a Chevrolet.
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
#19 |
Junior Member
#20 | |
20' Daredevil (Ret)
Fuzzy memory, but that's how I think it was. This would make sense to me... my black plate ends in "J".
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay Last edited by Stocker; 08-04-2010 at 01:15 AM. |
#21 |
Remember, this only a possibility, but unless you know who originally purchased your truck brand new, I say there is a possibility that it was probably traded in for a new vehicle in a dealership in 72 or 73. It might have been issued new plates to the new owner. Remember this is just my guess. My other guess is it probably had at one time a "H" or a "J" at the end of the black plate, most 71's did.
#22 | |
Moderator
My dad has an 86 Ferd Bronco that he purchased from the dealer in 1986. It was "dealer owned" and had 384 miles, and had blue plates on it. Blue plates stopped in 83, so why would it have blue plates??? ANSWER: The dealer carried them over from a previous vehicle that they owned. This is how plates from an earlier year vehicle end up on a later model. As long as the original registered owner (dealer or person) elects to retain the plates, they can be used again to register the subsequent vehicle. This is why you see blue and black plates on 80's, 90's, etc. model vehicles. The owner has had them since way back when, and has used them each time he has purchased another vehicle. This either clears it up, or adds another twist...
#23 |
*** That's interesting ***
My '69 C30 came from California, and it came with the original black plates. The format is "## ### X" where the letter is after the numbers. As far as I know, they were the original plates from '69.
Tom ![]() Chevy by day... 1969 Chevy C30 Rollback Tow Truck -- 383 stroker, 4L80E 2011 Chevy Caprice PPV 9C3 6.0L 1995 Chevy Caprice 9C1 1994 Chevy Caprice 9C1 #3 1995 Chevy Caprice Wagon #2 1995 Chevy Impala SS Mopar by night... 1969 Dodge Charger 1972 Chrysler Newport 2dr Hardtop (27K miles) Plus others... |
#24 |
Never Ending Projects
Mine are the original one from a '68.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
#25 |
Do you have a photo of that? I've never seen a original black plate with any letter further than "J" on the right side.
C/10 Rene 1966 Short Fleet "The Hag" 1967 CST Short Fleet "Dark Poly" 1971 Short Fleet 1970 Jimmy Custom 2 WD "Golden Ticket" 1972 Blazer 2 WD "Retro Blaze" Last edited by C/10 King; 08-04-2010 at 09:12 PM. |
| Bookmarks |
