where to buy a 700r tranny?
I am set on installing an overdrive tranny and had a guy all set to build me a 700r and Im not sure if i pissed him off or what but cant get a hold of him....so Im looking somewhere else
So when in doubt I look to you guys..... I have a 350sb punched out .60 over, edelbroc rpm heads air gap intake harland sharp roller rockers edelbroc cam, gear drive, edelbroc 800 carb. I want to buy a tranny but Im not sure how built it needs to be to last. or built at all? I plan on driving it on the weekends and to work once a week. But I do want to haul ass everywhere I go! hahaha. Any help would be greatly appreciated!!!!!!!! |
Future TOTM Winner
Re: where to buy a 700r tranny?
I don't have much help to offer, but this did make me laugh and spit Sunkist on my computer.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com |
sharp as a marble
![]() Join Date: Jan 2007
What trans is in your truck now? If it is a TH350, I would recommend a 200r4. It will be a bolt for bolt swap. No cutting the driveshaft ETC. If not then a 700 is the way to go. Search the local salvage yards, and find a 700 with a cable driven speedo. Find a small trans shop with a great reputation, and tell them what you want. If you want them to install it or you want to install it. Here is what you need:
700r4 trans and converter linkage to connect the TV cable to the carb wiring to the torque converter, and the correct connector to the trans 4 pin brake light switch YOU WILL LOVE WHEN DONE |
Hey someone was telling me about "Monster transmission". Are they any good..? Also my buddy was telling me there pretty reasonable..? Maybe gotta check into it further..?
Shawn 1966 short fleet 230 I-6 three in the tree (daily driver) 1966 short fleet big block th400 (building slowly) 1972 c10 3 door suburban 350 th350 (building faster than slowly) 2004 F250 power stroke (not dependable enough to be a daily driver) 2005 Kenworth T-800 Heavy Haul tractor (that's my true daily driver) |
If your looking for a mail order transmission you should check out Phoenix Transmissions. They do excellent work.
http://www.phoenixtrans.com/ |
i put a 700r4 in my blazer. works great, had it built to sit behide my 383 stroker with 465hp and 492 tq. seems to be holding up fine. you could always buy one of those raptor 700r4's. they builod them for 500-700hp. heres a link
http://www.transmissioncenter.net/highperf700r4.htm |
im thinking about doing this too but was wondering what the wiring to torque converter and four pin break lights were for?
68 C10 LWB 2/4 drop 406/th400/3.73posi 04 Silverado SS LQ9 6.0/4L65e/4.11posi AWD |
![]() Join Date: Jul 2009
Performabuilt transmissions has a good Rep. I am getting my trany from them when its time
1972 SWB Medium Olive South Houston Instagram: Antbish84 |
TCI has a wiring kit. You can also find it at Summit. The 4 pin brake switch is to unlock the converter when you apply the brakes. Also try Bow Tie Overdrives.
72 Fleet (died) 78 Step (sold) 55 Step named Fred (sold) 00 F150 68 Step (named El Scorcho by PO) Build thread for the new El Scorcho http://67-72chevytrucks.com/vboard/s...d.php?t=392932 |
Also try bowtie overdrives
James '68 Stepside (ground up in progress) My 68 build thread http://louisianaclassictruckclub.fre...side-t956.html '81 SWB "Pap paw" (Driver) The 81 build thread http://louisianaclassictruckclub.fre...-swb-t960.html Member of www.louisianaclassictruckclub.com https://www.facebook.com/groups/296290610747732/ |
where does the wiring and stuff go?
see http://static.summitracing.com/globa...tci-376600.pdf for wiring instructions.
Also this guy has an excellent writeup: http://www.rowand.net/Shop/Tech/LockupTCCWiring.htm
well Im glad I could make you laugh! haha
the truck originally had a straight 6 and three on the tree. So a stock rebuilt 700 should take 500hp is what it sounds like. I was looking on bowtie overdrive and they have some nice looking stuff but it looks like you pay for it! has anyone bought from them???? I have a 4.3L V-6 with a 700 on it that came out of an S-10 but wasnt sure if it was the same tranny I am looking for, the s-10 was a 91 or so???? I started looking at bowtie a while ago and they seem to be legit but at the same time my knowledge on trannys is very limited to say the least. 1300 for a tranny sounds like a chunk of money but I dont want to mess with it in the future! thanks for the input! |
i got myne from this website http://www.outlawtransmissions.com/v...es/default.htm 1.5 yrs ago mine runs strong i got the stage 2 700r4 with stage 2 shift perfect for every day driving. i couldnt be happier i got it out the door for 980 with converter give them a ring
#15 |
Is there a special 700 that I need to get??
I know that there are some small differences from the older 700's to the newer ones. What is a K case? it seems like that is a popular case???? are the newer 700's computer controlled, and does that mean I need the older style? is there a better 700 to buy as far as what year was a better or different one? Thanks |
#16 |
I finally bought a trans and thought it worked out pretty good!!!!!
700r4 "K" case full rebuild (not sure exactly what that means)- corvette servo- shift kit- 2500 stall converter- kick down cable... $980.00 with tax Built to handle 600hp??? is what he told me.he is a buddy of my friend that races NHRA so I kinda have some faith in him....... He said he made the trans a hydraulic lock up so I don't have to have a wire from my brake switch.... So what do you think? |
#17 |
I have a 700R4 behind a big block, had it for years now. I no one has ever told you, do not put a 700R4 in your vehicle. It was never intended to b behind an engine with a carb on it for many reasons!!! The drop in rpm's is small, first gear is a monster but I advise against it. If u still want a 700R4 after this, I will sell u mine. :}
#18 |
I went with Phoenix for my 700R4, I went to the shop in Wetherford, TX. Great people, and quality work
1969 C/10 Longbed undergoing rebuild. Old Chevy's Never Die, They Just Rust Around The Edges |
#19 |
Family Man
![]() Join Date: May 2010
Since ditching the idea of swapping over to a manual tranny, I will be looking to buy one from these guys.
http://www.gearstar.net/transmission....php?catunid=6 Pretty good deal: tranny, stall, cooler, fluid and no core required on most. |
#20 |
![]() Join Date: Jul 2010
There are many good trany shops out there. I have to say that Mark bowler, of Bowler transmissions is the smartest trans guy I've ever met. If you need a lock-up kit, and or a TV cable set up, he has the best stuff out there
#21 | |
#22 |
hey bro im in mesa i have a guy thats building me one if u have a core, ive known him for years and he provides the kickdown and the torque converter lockup pm me if ur interested
it usual better and faster if u figure it out yourself!!!! ![]() |
#23 |
Thanks dude! I just bought one.
