Old 08-05-2010, 11:18 AM   #1
64shortc10
64shortc10's Avatar
Re: My 65 Pickemup project
Powdercoating looks awsome! Whats is the back spacing of your centerline wheels? Are they the same back spacing front an rear?
In the first picture with your bed on the ground the tire is almost touching the lip of the bed?
In the second picture it looks like theres like 2 to 3inches between the tire and the bed lip? Do you Know how close it actually is in the second pic? The reason i'm wondering is my truck will be body dropped 3/4 of an inch and I was wondering if the tire would hit that lip? I want to put 24's on the rear of mine and dont know if they will fit with the body drop? Hope that made sense? Thanks!
Tony from Norcal
64shortc10 is offline   Reply With Quote
Old 08-05-2010, 11:20 AM   #2
64shortc10
64shortc10's Avatar
Also on the front does the tire touch the fire wall? Thanks again
Tony from Norcal
Old 08-05-2010, 11:34 AM   #3
Delmo
Delmo's Avatar
In the first pic obviously the box is just sitting on the ground so it tends to be a bit lower than it normally would be even with body drop. Having said that you will come very close to touching the lip with 24s depending on tire size. You can see in the 2nd pic that the box can come down another 3/4 of an inch but I can't pull that off unless I cut down my body mounts a bit, which I might do.
And the front does not touch the firewall.
Delmo is offline   Reply With Quote
Old 08-05-2010, 11:40 AM   #4
SCOTI
SCOTI's Avatar
If I might ask.... how much was your PC-ing bill?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 08-05-2010, 11:47 AM   #5
kart34
Question Re: My 65 Pickemup project
I would also like to know the powdercoat bill ? Would like to see Cali.pricing compared to Minnesota rates for referance since we own a powdercoating job shop. www.extremepowdercoating.net
kart34 is offline   Reply With Quote
Old 08-05-2010, 12:01 PM   #6
64shortc10
64shortc10's Avatar
Thanks! And do you know the back spacing?
Also you dont have to cut down the body mounts just lower them 3/4 of an inch. Thats how I did it.
