Old 08-04-2010, 11:37 PM   #1
67chevy2wd
67chevy2wd's Avatar
Which brand lift kit?
I am looking for an all suspension lift kit for my 71 gmc. Wanting 8"-10". I can't seem to find any place that sells them.
07 Chevy classic LBZ Duramax (a few mods)
'67 Chevy 1/2 ton 2wd (in pieces)
'69 Chevy 1/2 ton 2wd (on hold)
'71 GMC 3/4 ton 4x4
‘71 GMC 1/2 ton 2wd suburban
67chevy2wd is offline   Reply With Quote
Old 08-05-2010, 12:35 AM   #2
whtsierra68
Re: Which brand lift kit?
Here is Skyjacker's part number for their 8" lift - C280AKS.
http://www.skyjacker.com/products/pr...tail/?id=41761
whtsierra68 is offline   Reply With Quote
Old 08-05-2010, 12:04 PM   #3
67chevy2wd
67chevy2wd's Avatar
If I go with an 8" will I have to modify my drive lines?
'71 GMC 3/4 ton 4x4
Old 08-05-2010, 12:48 PM   #4
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
yes, you will have to have your driveshafts lenghtened. 4" pushes it, and I believe at 6" and above they will have to be lengthened. Also, I believe Skyjacker has the only 8" kit for our style out there, although Superlift may, but don't quote me on that. Trevor
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 08-09-2010, 10:58 PM   #5
D.PASSMORE
One of the First
D.PASSMORE's Avatar
Whew! 8-10 inches! Tell us it's not a daily driver! Just kidding! You will have to play with your angles on your axles and you might consider using latter bars to stabilize. Dual shocks also... Its a project with alot of mods. Hey, keep us posted...
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
'71 SWB K/10 CUSTOM DELUXE (Chili)
'72 BLAZER K/5 Muscle Truck (Mule)
'72 LWB K/20 CHEYENNE (Blackie)
D.PASSMORE is offline   Reply With Quote
Old 09-06-2010, 01:38 PM   #6
MATT SHIELDS
MATT SHIELDS's Avatar
I'm going with Skyjacker on my '72 K20. In researching I had found everyone stating they seem to ride the best. I ordered mine from 4wheelparts.com they seemed to have the best prices the also run specials with free shipping from time to time. The shipping charges are normally very high due to springs being very heavy.
MATT SHIELDS is offline   Reply With Quote
Old 09-10-2010, 08:58 AM   #7
67chevy2wd
67chevy2wd's Avatar
I am pretty set on an 8" now and no bigger. My buddy has a 79GMC with a 12" lift with 39" tires. He bought it that way and has thought about getting a smaller lift. I would go with a 6" if it saved me money, but the prices seem to be about the same.
'71 GMC 3/4 ton 4x4
Old 09-10-2010, 09:33 AM   #8
6772owner
Gearhead
6772owner's Avatar
I would think the driveline angles would be corrected in the spring packs, they usually include shims built right in. I sold truck accessories for 6 years and never saw a lift that big that didnt have the shims right on the packs. You will definetly need the shafts extended, I would look into the 8" and make sure that you dont need a CV stlye driveshaft or have to "reclock" the transfer case. If it is a S/B, I would be concerned of the rear driveshaft angle at that height. Just my .02
2002 Saturn SL2, My D/D
2019 Ford Fusion SE, Ecoboost - Wife's D/D
1993 Camaro Z28, A4, CAI, Cat-Back Exhaust
Project C10 (my 72' C10 w/96' LT1, 700R4, bagged F&R, 18's (for now), Short/Fleet) -- SOLD!
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=313644
6772owner is offline   Reply With Quote
Old 09-10-2010, 11:31 AM   #9
Cbrown67
awesome!!!
i am thinking of the same exact thing for mine
Cbrown67 is offline   Reply With Quote
Old 09-10-2010, 04:18 PM   #10
swamp rat
swamp rat's Avatar
Mind if i pick your brain for some info? I have A 72 3/4t and about 12 years ago i put a 4" rancho kit on it that has front springs and rear blocks with 5000 series shocks, it definantly made foe a much bumpier ride than stock.
I'm getting close to the point where i want to go ahead and replace the rear blocks with a spring kit so was looking at this kit:
http://www.4-wheel-drive-lift-kits.c...r-springs.html
Do you think from your experiance that this kit will have a better ride than the rancho kit i have? Thanks!
swamp rat is offline   Reply With Quote
Old 09-10-2010, 04:55 PM   #11
6772owner
Gearhead
6772owner's Avatar
I have heard that the Skyjacker kits ride better than most of the other kits available. The thing to remember is that a spring rides progessively worse the more arch it has in it, BUT the lifted springs tend to be softer than "factory" springs. They usually have more leaves than stock, but are usually thinner (and sometimes tapered) to help with "flex", which is better for ride quality. So long story short, I would bet the full replacement springs would ride better for you at a 4" height, any bigger than that and the arch is gonna start killing ride quality again. I also believe that a quality (read Bilstein) shock goes a long way as well. Just my .02
Old 09-10-2010, 10:12 PM   #12
swamp rat
swamp rat's Avatar
Thanks for the reply! The other option i have would be to try installing different shocks, are you suggesting the Bilstines may be better than the Ranchos? maybe a little less high speed dampening?
