Old 08-05-2010, 01:43 PM   #1
dewey777
dewey777's Avatar
Re: Gas tank filler neck
Originally Posted by OrrieG View Post
I thought about that too after I saw a 65ish fleetside that had adapted it. Tight fit for everything to fit, led takes up a lot of room and could not reconcile liquid gas & fumes with electrical arcing from the light. I have decided to use a Harley flush popup mounted on top of the bed rail just in front of the rear stake pocket. Will run 1.5 steel pipe next to stake thru bed floor then over to the tank. I will fab a plate around the pipe in the bed to protect it. I did not want to drag the hose across the tailgate or bed top either.
I haven't done much research yet but the LED should be thin in comparison to the stock incandescent and LED's are sealed so there is no arching issue. I agree things would be tight.
I can't find any better pictures than these....
1959 Chev Apache 3100 Short Fleet Big Window
dewey777 is offline   Reply With Quote
