Closed Thread
Old 08-04-2010, 06:03 PM   #1701
Daddy64
Re: What did you do to your truck today?
Sitting in filler primer waiting for finish sand and paint
Daddy64 is offline
Old 08-04-2010, 06:09 PM   #1702
SRVBLUES64
send some pics
SRVBLUES64 is offline
Old 08-04-2010, 10:35 PM   #1703
DRTYRAT30
Jesse
DRTYRAT30's Avatar
Took my trailing arm crossmember out with the cab on. What a pain in the A$$ the 4 rivets on top are to get.
DRTYRAT30 is offline
Old 08-05-2010, 05:40 AM   #1704
63sbssbbw
UCA63
63sbssbbw's Avatar
Are you gonna flip it or replace it?
T
member#7816
"63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt
'61 GMC in progress
'63 GMC to use for parts
'90 Chevy Ext cab sbfs 5.7l (current d d)
63sbssbbw is offline
Old 08-05-2010, 06:15 PM   #1705
DRTYRAT30
Jesse
DRTYRAT30's Avatar
T
Replace it with a Porterbuilt Trailing Arm kit
Old 08-07-2010, 05:56 AM   #1706
fryer1979
Redneck Hillbilly
fryer1979's Avatar
Would flipping that crossmember alleviate some of the trailing arm issues that come with lowering the rear end?
fryer1979 is offline
Old 08-07-2010, 06:03 AM   #1707
63sbssbbw
UCA63
63sbssbbw's Avatar
Yes,although once flipped the top (the old bottom)needs a bit of modifying to clear the cab.
T
member#7816
'61 GMC in progress
Old 08-07-2010, 06:28 AM   #1708
fryer1979
Redneck Hillbilly
fryer1979's Avatar
probably nothing a little grinder couldn't fix though, maybe a little cut and weld kind of thing...
Old 08-07-2010, 07:28 AM   #1709
63sbssbbw
UCA63
63sbssbbw's Avatar
A bit of cut and weld for sure
member#7816
'61 GMC in progress
Old 08-07-2010, 11:47 AM   #1710
65Gregg
65Gregg's Avatar
T
Please explain how flipping the crossmember helps on a lowered truck. Is this something that is beneficial on a static drop?
65Gregg
Blue long bed
White TBSS
61 Impala
“The two most important days in your life are the day you are born and the day you find out why.” Mark Twain
65Gregg is offline
Old 08-07-2010, 02:50 PM   #1711
markeb01
Senior Enthusiast
markeb01's Avatar
In the factory setup the pinion angle of the rear end is established (along with the axle perches) by the mounting orientation of the forward and rear ends of the trailing arms. By raising the rear axle up in the chassis (lowering the truck) the pinion is now pointing nose down aggravating the driveshaft angles. By inverting the position of the forward trailing arm brackets, the trailing arms are now restored to their factory alignment (assuming the rear axle and the forward trailing arm pivots are raised the same amount.
markeb01 is offline
Old 08-07-2010, 09:31 PM   #1712
SCOTI
SCOTI's Avatar
^^ The easier way would be to remove the OE trailing arm mounts from the c.member & invert them if the pinion angle is all your looking to change.
If you want more clearance & better pinion angle, yank the c.member, flip it, flatten the bottom of the c.member so it's flush w/the frame rail, & raise the top of the c.member 'loop' to gain some much needed d.shaft clearance.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now
Old 08-08-2010, 07:26 PM   #1713
Daddy64
Finally some color!
Daddy64 is offline
Old 08-08-2010, 08:27 PM   #1714
tomlamb
Tried to figure out ball joints and tie rods for my 66....
tomlamb is offline
Old 08-08-2010, 08:36 PM   #1715
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Originally Posted by SRVBLUES64 View Post
Any thoughts on my engine , Like I said on another post I got this for 150 the clylinders look to be good shape, what should I do next? Im having a bit of a hard time putting pics in, Ill get back to it soon, anywauys all looks good I have plans to paint and all th bracket or chrome everything I can. Any thoughts on just what I should replace and also cam what size is cool with changing the TC Thanks Jeff
You might get more replies in the engine section. I vote to get the machine work done. Just my .02
Alan's Classic is offline
Old 08-08-2010, 10:24 PM   #1716
markeb01
Senior Enthusiast
markeb01's Avatar
After 20 years on the rear shocks and 13 on the fronts, I finally installed new Gabriel gas shocks front and rear. The old front Monroe Gas Grande shocks remain so stiff it takes quite a while to compress them by hand. The new versions are soft by comparison with about the same resistance as the rears. They look wimpy compared to the old ones, and I was a bit concerned about their ability to handle the suspension. A quick test ride revealed greatly improved ride quality. The truck used to pound into rough roads and now seems to glide over rough patches (of which we have a lot). There doesn't seem to be any noticeable loss of cornering ability, so at the moment I'm happy with the change.
markeb01 is offline
Old 08-09-2010, 12:31 AM   #1717
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
moved it out of the carport
Gage
1967 C10 Shortbed Stepside
jgh64pkup is offline
Old 08-09-2010, 05:14 PM   #1718
Byronic
The Beach Cruiser
Byronic's Avatar
Finally gave it a roof over it's head.
1999 Silverado DD
1966 Panel Truck
2003 Harley Road Glide
1967 Schwinn Tandem Single Speed
Byronic is offline
Old 08-09-2010, 06:16 PM   #1719
jkb
Drive Train installed, Steering all done and the front end put back on. I might just make it to Woodward this year but I'm cutting it a little close.
"All Alone Meet & Greet 2010."
http://67-72chevytrucks.com/vboard/s...d.php?t=393754
jkb is offline
Old 08-10-2010, 01:51 AM   #1720
fryer1979
Redneck Hillbilly
fryer1979's Avatar
After spending all day, night, and following morning at the Hot August Nights show in Reno over the weekend, I got a lot of the junk cleared out of my shop. We had been piling stuff out there for the past few weeks because of the few house parties and bbqs we've been having. So I spent most of Sunday evening and today before work getting it mostly sorted and cleared out to more proper locations. Gotta make the room for the cab and bed that will be soon coming off. Not much specifically on the truck itself, just getting tools cleaned and ready, and making more room. Found quite a bit to sell on craigslist too, nothing 60-66 related though.
Old 08-10-2010, 05:44 PM   #1721
rockhop051
Sanding, disassembly and more sanding!
Ordered my dual master cylinder conversion along with new brake lines, tube bender and flaring tool.
For the engine I have new rings, cam and lifters, oil pump and gasket set. Pretty much clears out the bank account but gives me plenty to do. Will be starting a build post soon.
John
66 Chevy C20
rockhop051 is offline
Old 08-10-2010, 07:22 PM   #1722
Gary66
Gary66's Avatar
been cussing a cracked 283!
2003 2500 HD Crew Cab
1965 GMC K10
1972 Chevrolet k5 blazer
Gary66 is offline
Old 08-10-2010, 10:21 PM   #1723
losthope
losthope's Avatar
i replaced my grill today !!
BEFORE!
AFTER!
losthope is offline
Old 08-11-2010, 08:20 PM   #1724
bubba327
HOW long until spring??
bubba327's Avatar
A wonderful day.. A trip to the alignment rack where things went perfect on the 71 front end which I put in last year
Size:  32.9 KB A stop at DMV for registration and plates.. A call to my agent for Insurance.. And when it quits raining this evening... A short road trip!!
I did crack a molar tooth today that will need a crown . BUT it was a truly happy day!!!! Finally getting close after a year and a few months of rebuilding and replacing.
69 chevelle convertible
71-C-10 short-wide and low
64 C-10 custom shortbox "Bubba"s Recycling project"
bubba327 is offline
Old 08-11-2010, 09:03 PM   #1725
Malibob
Malibob's Avatar
I STARTED IT. I had to put new head gaskets on it so I finally finished it today. A lot of fine tuning though from this point forward. Woo hoo
This statement was made possible by a grant from this station and continued support from viewers like you.
Flickr
Malibob is offline
Closed Thread
