#26 |
Re: El Chingon
lowering blocks fabbed for the rear:
#27 |
Re: El Chingon
got the wheels for the project, wheel vintique 17x8 for the front, 17x9 for the rear. thinking about 255 50 17 front, 275 50 17 rear for the tires. hope it has enough side wall and does not look goofy.
#28 |
low n' slo
![]() Join Date: Mar 2009
Re: El Chingon
very nice man, i may have to check this one out in person some day..
67 1/2 ton Suburban - Project DRGNWGN. Build thread ![]() -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
#29 |
VA72C10
![]() Join Date: Mar 2008
Re: El Chingon
looks like a sweet project!
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#30 | |
![]() Join Date: Jul 2009
Re: El Chingon
1972 SWB Medium Olive South Houston Instagram: Antbish84 |
#31 |
Sofa King Crazy!!
Re: El Chingon
What kind of centercaps are you going to run on the ralleys?? I have a set of ralleys for my truck also but I am thinking of changing the center caps.
You found the Tater. ![]() My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650 My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650 67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS. ![]() 1972 2wd Blazer "Porterbuilt and Sloshed" ![]() Last edited by Slick67; 08-05-2010 at 09:48 PM. |
#32 | |
Re: El Chingon
custom coating applicators was the name of the company. i have the card at work for the number if you want it . pm me and i will give you the number. |
#33 |
Re: El Chingon
going to run smooth trim rings with the derby style cap, it is all on order and waiting for it to come in. the real caps are expensive and so are the rings. i could have bought a set of billet wheels for what i am going to have in these things. it will look nice and old school. that is kinda how i am, and wish the world would sometimes be.
#34 |
Re: El Chingon
PM sent
#35 |
Re: El Chingon
well i removed the energy suspension bushings and threw them as far as i could, pressed in the moog replacement bushings in the lower arms. my lower arms must have been a little tweeked, hence i had to use a porta power to straighten them. once i had the bushings pressed i had to trim the hell out of them to get them over the dropmember. once that was done i had to trim the inner sleeves supplied with the dropmember. now everything is dialed in it seems to a pretty good system. i coated the inner sleeves with never seeze just in case i want to take it back apart down the road. if you buy the porter built a arms i bet it is just a slide together system, with mine mixing new with old it took some tweeking, i hate tweeking freshly painted parts. nate was a big help with my questions and answered them quickly, A+ for nate and quality customer service once again. pics of the work so far:
#36 |
Re: El Chingon
got the rear back tonight and started mocking stuff up for the final time(maybe)
Thing is covered in fingerprints, every time i touch the damn thing it makes me mad. i am using all the suspension stuff of of the truck i hung up on the manhole. It should be a nice daily driver when done. |
#37 |
Re: El Chingon
one more of the full package
#38 |
Re: El Chingon
nice setup bro looks really good and organized
#39 |
Re: El Chingon
Got Capt. Fab bolted up and test fitted:
#40 |
Re: El Chingon
finally got the rack trimmed and installed:
#41 |
Re: El Chingon
kinda on a side note, i want to thank nathan at porterbuilt street rods for assisting me on another project. he helped with me some frontend problems and geometry. once again class act guy. here is some pics of it after about 400 hundred miles with zero issue.
#42 |
VA72C10
Re: El Chingon
Frame's looking good and nice dually!
#43 |
low n' slo
Re: El Chingon
nice man, im gonna have to check this one out some time.
sick dually too..
67 1/2 ton Suburban - Project DRGNWGN. Build thread ![]() -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] Last edited by kev2809; 12-11-2010 at 09:46 PM. |
#44 |
Re: El Chingon
thanks guys, it is hard enough trying to one build, two is really hurting my wallet. the dually is close enough now where i am going to just drive it for a year. going to dump all my cash into the c-10 now. should come together rather quickly now.
looking for a 5.3 GenIII motor with a 4l60e that is drive by wire. you would think in houston that would be easy. not! |
#45 |
Re: El Chingon
#46 |
low n' slo
Re: El Chingon
lol thanks for checkin out the build. i know what u mean about not having a garage, it sucks. i just wish i at least had a concrete driveway lol hey, maybe i missed it but what brackets did you use for ur rear bags?
#47 |
Re: El Chingon
all the rear brackets came from clint over at kp components including the shock brackets, the front stuff all came from nathan at porterbuilt street rods. i suggest to everyone that looks at this to give nathan a call before doing any kind of suspension mod. if he dont have it, he will make it.
#48 |
Re: El Chingon
finally got some wheels on in and cycled the suspension, had to loose the drop spindles and go with stock spindles to achieve more lift in the front. i am only running a 26" tall tire in the front. back almost lays out, need to drill some holes in the rear shock mounts so i can adjust them. man i just realized how dirty this frame is. need to get out the quick detailer and rub her down.
#49 |
Sofa King Crazy!!
Re: El Chingon
We are patiently waiting for and update from ya, with some more pics. Soon, it will not be patiently.........
You found the Tater. ![]() My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650 My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650 67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS. ![]() 1972 2wd Blazer "Porterbuilt and Sloshed" ![]() |
#50 |
fat old dude
![]() Join Date: Feb 2010
Re: El Chingon
looks awesome
1972 c-10 shortbed 350/400 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=389157 1968 workhorse http://67-72chevytrucks.com/vboard/s...d.php?t=446216 Accepting part donations |
